The K & P ,,Seehund" wreck.
GuestTags: None
Thank you all for dropping in.
Hi Ken we got there together, thank you :thumb2:
Cheers Scottie I'm pleased you like it.
Thanks Ian,I learnt a bit doing this one which is always good.
Hi Ferando thank you very much it was a bit different from my norm.
Old Puffer Pete.Comment
Nice one Pete, that certainly gave the effect of years worth of corrosion. I shall remember that for extreme areas of rusting.Yes the sea weed on those mine cables did look good, giving the effect of water movement. So much to think about when modelling something like that.
John.
Hi John glad you like all bit and bobs did you see the sea weed on the edge rocks and mine cables, as for corrosion, primed with the darkest rust colour I had, coated with 75% PVA /25% water and very fine washed sand and let dry, the sand I used was from Sword Beach the one William "Bill" Millin played the pipes whilst under fire during the D-Day landing I got some from all the D-Day beaches :rolling:
The guys have said it all Pete. You must be very pleased:thumb2::thumb2::thumb2::thumb2::thumb2:Comment
