Afghanistan British Aircraft & Vehicles 1/48
    When I wandered away I had half finished the components of this diorama which I presented
    individually as builds & reveals.
    Depicts near 100% the equipment used by Britain in the field operations.
    More a pictorial containing a number of dioramas.
    My favorite build was the Afghanistan house. Spending 50 years in architecture first building
    I have designed with out client interference.
    [ATTACH]347695[/ATTACH] [ATTACH]347696[/ATTACH] [ATTACH]347697[/ATTACH] [ATTACH]347698[/ATTACH] [ATTACH]347699[/ATTACH] [ATTACH]347700[/ATTACH] [ATTACH]347701[/ATTACH] [ATTACH]347702[/ATTACH] [ATTACH]347703[/ATTACH] [ATTACH]347704[/ATTACH] [ATTACH]347705[/ATTACH] [ATTACH]347706[/ATTACH] [ATTACH]347707[/ATTACH] [ATTACH]347708[/ATTACH] [ATTACH]347709[/ATTACH] [ATTACH]347710[/ATTACH] [ATTACH]347711[/ATTACH]
  • PaulTRose
    • Jun 2013
    • 6464
    • Tattooine
    lot of work there, really nice
    Per Ardua
    • Gern
      • 9218
      That's impressive stuff Laurie - I like it a lot!
      Can I just say I reckon your figures would look much better without their bases. A drop of CA would fix them directly to your dio base - or do you need to be able to move them?
        Thanks for looking in & your comments very much appreciated.
        Originally posted by Gern
        That's impressive stuff Laurie - I like it a lot! Can I just say I reckon your figures would look much better without their bases. A drop of CA would fix them directly to your dio base - or do you need to be able to move them?
        Thanks Dave very much appreciated.
        Agree the figures are difficult. In the phots i had been moving them around so they were not at there best.
        Problem is the grass. Originally tried figures stuck to the grass but after a day or so they fell over or looked drunk.
        What I have done is to put the base plate on. Using PVA stuck grass, in packet form, letting it over lap. Then the base
        plate sticks ok to the grass mat. Then used fine git to sprinkle around the edge of base plate to camouflage. Finally
        where it did not quite look right I have used mini tufts of grass, gorse or small stones (look like rocks) placed
        surreptitiously around the base plate.
        • colin m
          • 8755
          • Colin
          • Stafford, UK
          Brilliant Laurie. I remember seeing a few of the individual components being built, but this might be my first time seeing everything together. Very nice.
          • JR
            • May 2015
            • 18273
            I take my hat off to you Sir, brilliant display with the photo back ground. Very nice indeed .
            • PaulTRose
              • Jun 2013
              • 6464
              • Tattooine
              when i used the figures i drilled a hole into a boot and up a leg and glued in a sewing pin......cut the head off.....and that made a support to push into the 'ground'
              Per Ardua
                Hey that is a brilliant idea Paul. Will adopt.
                BUT does the soldier not look a bit odd with out his head :flushed:
                Laurie :tongue-out3:
                  Excellent work all round :smiling3:.
                    Thanks Colin very much appreciated. Yes there are 16 units plus 2 platoons.
                    Your reply very much appreciated John
                    Thanks men Laurie
                      • 15702
                      Hi Laurie
                      A stunning result. A huge dio and a huge amount of work.
                        Originally posted by Jim R
                        Hi Laurie A stunning result. A huge dio and a huge amount of work. Jim
                        Thanks Jim very nice of you to say so. Yes a lot of work. over 6 years.
                        Fortunately I manage to keep myself in check & not rush to get to the end.
                        After saying that I have found more & more slowly is quicker. Minimum
                        errors & satisfaction which makes model making a very happy place.
                        On a larger one now. Falklands both British & Argentinian 25% along the line.
                        Being difficult & a bit expensive tracking old kits down.
                        • PaulTRose
                          • Jun 2013
                          • 6464
                          • Tattooine
                          [ATTACH]347712[/ATTACH]
                          Per Ardua
                            I like it Paul :tongue-out3:
                            • Mini Me
                              • Jun 2018
                              • 10711
                              Very well executed Laurie. The placement of men and machines was very well thought out and flows very nicely with the back drop.
                              This is definitely one to be proud of and I'm looking forward to your next presentation. Rick H.
