Wobblys Workshop The Ambush
  • Wobbly Woofer
    • Mar 2022
    • 35
    #16
    Originally posted by Mini Me
    Well done Mr. Wobbly.......is it 1/35 scale or smaller? Very well integrated when viewed from any angle. :thumb2: And you got the "Dog's" right out the gate!! Rick H.
    Hi Rick, Thanks for the comment, Yep all done in 1/35-Wobbly Take care
    • adt70hk
      • Sep 2019
      • 10406
      #17
      Very nice!!!
      • Wobbly Woofer
        • Mar 2022
        • 35
        #18
        Tremendous diorama Mick .Can you tell us more about the brick work, esp the brick circle in the center, very neat indeed .
        The committee were also impressed, so much they have awarded you a .
        [ATTACH=CONFIG]n1172672[/ATTACH]
        Congratulations.
        Hiya John, sorry about delay in replying, Brickwork just scribed into foam.... Black primer, Then I wet blended "Brick" colours using a bit of sponge. When dry used Watered down pva on grout lines then sprinkled with my finest sand. Let it dry and then went over with a dry stiff paint brush. Quite a lot of the sand brushed off but I was pretty pleased with the result . I would normally have gone down the "Dry Brushing route.... but I'm well impressed with the finished result...and will use it again. Wonder if it will work on a stone wall? Have had some nice comments about the Dio, and look forward to being able to both learn and perhaps even contribute a little to the group. Take care and happy modelling -Mick
        • JR
          • May 2015
          • 18273
          #19
          Thank you Mick.
          It's a most impressive way of achieving that most realistic look . I was interested in the use of watered down PVA and the fine sand , I normally use grey pigment rubbed into the mortar line , but seeing your method looking like that have a play .
            • 18901
            Sorry, must have missed this :flushed:. Excellent dio wobbers. Plenty to look at, nice sense of movement and urgency, and great brickwork with properly coloured mortar….what’s not to like:thumb2:
