I decided to have another go at a winter scene. The scene is based on a real scenario but different truck. The icicles were made by holding clear sprues over a candle, and slowly pulling the two halves away from each other. The frost was made using Green Stuff Frost solution. Two methods you can use;
1. The cheapest, which is to mix salt in warm water with a drop or two of detergent; and pour it into a spray bottle and spray it on. It takes about 10-20 minutes to crystallize.
2. you can buy frost solution by Green Stuff. The icicles were made by holding clear spruce over a candle and pulling slowly until you achieve the desired length. Then it is just a matter of cutting the ends to the desire lengths.The snow was made by my usual standards as before, on the other DHL truck scene I did many months before.
