Just finished, didn't use their method of wrapping tape around the wires joins, used a terminal block instead. Not bad build, instructions great at the start , a bit vague towards the end. Would recommend for something different.
Be prepared for some sanding of tabs as the openings are tight. All in all a fun build. The touch switch is great.
Thanks for following and commenting. John.
