Valentine Mk 1 1/35 scale AFV CLUB AF 35178.
  • JR
    • May 2015
    • 18273
    After removing that last pour which failed to harden , no doubt my fault , not with the mix but cross contamination. That can be the only reason I can think off .
    I was left with a diorama tilted up at the back so any resin could gradually run, creep down on to the silicone mat. Glad I bought those pointy paint drying things as they were really good at keeping the dio up as it sat on the bench.
    I had to remove all the Lilly's , and flowers, clean and allow to dry. Once the new resin had arrived I set too. This time it was a 1/1 mix, thin layers so decided this would be perfect.
    Did the mix, pour , then the cover and waited, looking once to check for bubbles. Once dry I gave it another 3 days before I added those Lilly's and some flowers. Then did a little gardening at the back of the tracks , mainly to show vegetation taking hold.
ID:	1230167Click image for larger version
ID:	1230168Click image for larger version
ID:	1230169Click image for larger version
ID:	1230170Click image for larger version
ID:	1230171Click image for larger version
ID:	1230172Click image for larger version
ID:	1230173Click image for larger version
ID:	1230174Click image for larger version
    Thanks for looking and the support along the way.
  • Scratchbuilder
    • Jul 2022
    • 2689
    Nothing more to say, it has all been said before, once again excellent build.
    • Mark1
      • Apr 2021
      • 4156
      An excellent result yet again.
        • 15655
        That really is superb John.
        • Neil Merryweather
          • Dec 2018
          • 5182
          • London
          I can't help it, John,it's even better second time around!
          • Andy the Sheep
            • Apr 2019
            • 1864
            • Andrea
            • North Eastern Italy
            I had a very pleasant catch up on your build, John. It's fantastic!
            Sorry for having missed this thread but recent real life was a bit messy... better late than never, anyway.
            • Si Benson
              • 3572
              Excellent fix John, it all looks absolutely fantastic :smiling4:
                I like that a lot
                • JR
                  • May 2015
                  • 18273
                  Many thanks Wibble.
                  Cheers Mark.
                  Thanks Jim.
                  I was determined not to be beaten Neil, thanks.
                  That's ok Andrea, glad you looked in.
                  Cheers Si , come a long way since my early attempts.
                  Originally posted by Jakko
                  I like that a lot :smiling3:
                  Appreciate that . :nerd:
                  • minitnkr
                    Charter Rabble member
                    • 7517
                    • Dayton, OH USA
                    Beautifully executed Dzohn....... and w/o flames.
                    • Andy T
                      • Apr 2021
                      • 3239
                      Sorry to read you had issues with the resin John but it looks excellent now
                        • 18266
                        Moved as requested to the completed section John.
                        I must say it turned out very well indeed. Great job and worth the effort.
                          • 18890
                          Love it :thumb2:
                          • JR
                            • May 2015
                            • 18273
                            Thanks Paul, yes it was hard to to set anything alight this time.
                            Cheers Andy, my fault I think .
                            Thank you Ian.
                            Love it :thumb2:
                            Cheers Tim.
                            • JayCee
                              • Aug 2019
                              • 1131
                              John, will you please stop showing us photo's of real wrecks. Seriously though, that is Bl**dy marvellous. These dioramas really are your forte.
                              John.
