Thanks ole, couldn't let the colonials have all the sentence could I?!
O.K., as it's raining, I've grabbed a bit of modelling time and moved onto the water and made a start on the pool. To get a sense of depth I started with a light colour, then getting darker towards the middle, ending up in almost black at the 'Bottom' This tricks the eye into thinking the fake water really is getting deeper.
If you look closely at pics. 1 & 2, you can see the 'ledge' I have formed around the perimeter of the pool, this is where the plastic sits....
Then I made a template of the surface shape and transferred this to my plastic - which was the lid from a box of Christmas crackers - cut this out and glued it in position on the ledge...Job done, apart from later, when a little 'touching up' around the edges to blend the water/ stones together will be needed.
Easy to do, no mixing, smell, heat, cracking or cost...We needed the crackers anyway!!
Jim, nothing wrong with using resin. There are loads of great examples of resin water here on S.M.......It's just that I find the plastic fool proof and easy to use. Which is a big plus where I'm concerned!!!!! lol
Thanks Andy and Trey for your positive comments about the pool.....
It really is a very easy method of 'making' water and gives a nice finish. The important part is getting the pool bottom painted right to make sure the illusion of depth looks right, because the plastic gives a crystal clear finish. There are various ways of dulling it down if required, just rubbing your fingers over it is one!
