Working on this for a while. I have been looking at many pics of Slum areas from around the world and thought it would be 'different' to model something using this subject matter as an inspiration. I have not seen many or should I say, this subject matter, modelled before. As always, I try to be different and not follow a certain trend. So here is what I have modelled so far.
The corrugated zinc, were done using foil paper and a mechanism that makes the corrugated design. I bought from some store. I do not remember but you can get a similar one from Panduro. I am cheap, so I will use anything possible. But I found another material. Use aluminum platter that bakers use to put cakes or food on. I found some cheaper ones at a cheap store for very little money. I cut out everything around it and use the bottom which was perfect. Thanks for looking.
BTW, if you type in Slum in Google's search window, you will see many different types from around the world. It is a shame, all governments do not put in the efforts to change this. With all the money they put into their military and such.
Apologies for the bad photos. My camera got smashed a couple of times and the plastic has lots of scratches which leaves a shadowy cloud at the bottom of the camera. So it is hard to adjust.
