Hi all, It's encouraging to see there are a lot more people thinking about or indeed having a go at dioramas on here than 2yrs. ago, so I thought I would share this build with you all and hope it might give some help and incentive to the 'Dio.' movement, especially as we have some desert dios. in the offing soon
I have never built anything to do with Afghanistan or that part of the world, so a quick look at google images gave me a rough idea what a typical dwelling looks like. From then on I just imagined things and let the ideas flow.
The build:
As some of you will know, I never buy anything for my dioramas but scrounge stuff from the garden, kitchen, the garage or shed.
The base is a 13" X 15" scrap piece of 1/2" chipboard.The main house structure consists of two old polystyrene plant trays, (I hit on this when I wanted summat for a bunker for my 'Omaha Beach' G.B. model) I cut one in half, turned it upside down and placed it on top of the complete tray. This gave me an instant roof! (I needed the extra bit on top 'cos one on it's own wasn't high enough.
I cut out some window and door openings with a junior hacksaw blade then stuck it all together and to the base with my usual floor adhesive. I also at this stage spread some left over adhesive on the walls for a bit of varied texture. The two 'garden walls' are made from strip polystyrene.
Once the basic structure was done, I rooted out some old yellowy emulsion paint from the shed and gave the whole thing a first coating.
After that dried I painted the building and walls with well watered down P.V.A. and collecting sweepings from the garage floor and the drive, I literally threw this mixture at the model, then tapped the base to remove the residue.
This gave me a nice texture for the next bit of weathering...
I mixed some brown shed paint with my P.V.A. solution and painted downward streaks on the walls of the house and then threw more stuff at this. This gave a nice dark brown blotchy effect to the walls. I left the painting to dry and turned my attention to a bit of detail.
I wanted a rickity lean-to at the side of the house, so I found some dead twigs of the right scale from the garden and constructed it with these using 'Uhu' glue.
For the corrugated roof I used aluminium baking foil layed over cocktail sticks and scoured with the back of my modelling knife to give the corrugations, then fixed it to the frame work of the lean-to.
The window frames, shutters and door I made from some scrap balsa, then painted with a brown wash.
That's it for now, next I will turn my attention to the 'Garden' and the road.
I hope you approve of progress so far and perhaps gained some tips on ways to be a cheapskate builder!
The pictures show the initial construction and the progress so far.
Thanks for taking the time to look.
Ron
[ATTACH]33889.IPB[/ATTACH]
[ATTACH]33890.IPB[/ATTACH]
[ATTACH]33891.IPB[/ATTACH]
[ATTACH]33892.IPB[/ATTACH]
[ATTACH]33893.IPB[/ATTACH]
[ATTACH]33894.IPB[/ATTACH]
[ATTACH]33895.IPB[/ATTACH]
[ATTACH]33896.IPB[/ATTACH]
[ATTACH]33897.IPB[/ATTACH]
[ATTACH]33898.IPB[/ATTACH]
[ATTACH]33899.IPB[/ATTACH]
[ATTACH]33900.IPB[/ATTACH]
The build:
Ron
