Do you want it mate ?It's yours I think to make it look really good would be a challenge for me but I'm sure you could do it with your easy closed
Nonsense, it's 90% done, just add what you want, some small burnt matchsticks etc for a building sticking out the snow, some snow drifts etc, a bush or two.
Ok mate I did like your wrecks idea and I do have some landscape dead trees that look burnt she'll wholes might be a problem as this is small the base isn't even a4 size but the rest is doable
Ok mate I did like your wrecks idea and I do have some landscape dead trees that look burnt she'll wholes might be a problem as this is small the base isn't even a4 size but the rest is doable Guess I'm keeping it then
Yes, keep it, a small easy dio, not in the way or much work, just enhance it slighlty.
