What to do with this ?
    Originally posted by \
    It's powdered glass mate
    Powdered glass!!
    A tad hazardous maybe?
    • Alan 45
      • Nov 2012
      • 9833
      #17
      Powdered glass!! A tad hazardous maybe?
      Only if you eat it , it's used as a cleaning agent and as long as you use a mask and use a sifter it's perfectly safe
      • tanktrack
        • Jun 2012
        • 1429
        #18
        don't forget vehicle tracks/impressions
        • monica
          • Oct 2013
          • 15169
          #19
          a lot has been said that i would off ,have the tank coming out of its hiding stop after being shelled,so some bushes and shell hole,with some burnt trees,
            I'll stick with my bicarbonate of soda mate!
            • flyjoe180
              • Jan 2012
              • 12429
              • Joe
              • Earth
              #21
              I think Hayley's suggestion of some mud/dirt and some gear laying about would work Alan. Steve's track marks too. And also Monica's burnt tree and maybe her and Si's shell hole. So much potential in that base.
                Nothing to get cut up about Patrick I'm sure.
                • spanner570
                  • 15428
                  #23
                  Alan, If it's a fairly soft base how about gouging out a small stream running through the base and have one of the tanks slid into it......the shell holes could have some water in the bottom too.
                  A muddy track would look well alongside the stream, leading to an abandoned farm building, where a top secret aircraft was being hidden from the Allies, but it's location is known and you could have elements of the US 101st Airborne dropping out of an aircraft suspended above the dio. Some who have landed earlier could be creeping along the stream ready to attack the building...
                  Also there would be room for a battery of 88mm anti-aircraft guns shooting at the incoming aircraft and then.....
                  Watch out my nurse is here with my sleepi....ZZZZZZZZZZZZZZZZ
                    I think you should do all the suggestions plus you could have a hovercraft coming up the stream and maybe if there's still room you could have a battleship and a squadron of ju87s, just an idea, or I suppose you could do your own thing
                    • Alan 45
                      • Nov 2012
                      • 9833
                      #25
                      I can get away with that as I'll be doing it as abandoned so the snow would of filled in the track marks
                      • Alan 45
                        • Nov 2012
                        • 9833
                        #26
                        Alan, If it's a fairly soft base how about gouging out a small stream running through the base and have one of the tanks slid into it......the shell holes could have some water in the bottom too.A muddy track would look well alongside the stream, leading to an abandoned farm building, where a top secret aircraft was being hidden from the Allies, but it's location is known and you could have elements of the US 101st Airborne dropping out of an aircraft suspended above the dio. Some who have landed earlier could be creeping along the stream ready to attack the building...
                        Ron stick to squirrel bating
                        • Alan 45
                          • Nov 2012
                          • 9833
                          #27
                          Thanks ken I'll take that under advisement
                            What you're not doing my suggestion I thought you would jump at that that's a shame would have been awesome was hoping to see the finished thing tomorrow
                            • Alan 45
                              • Nov 2012
                              • 9833
                              #29
                              I would have done it mate but I only have a 1/24 scale stuka and that's just a scale above the so I'm sorry mate
                              • eddiesolo
                                • Jul 2013
                                • 11193
                                #30
                                I have an idea Al, don't do anything with it and set to and do that bust I sent you.
                                Si
