what to use for making a brick building?
  • bazers
    • Oct 2013
    • 2611
    Hi guys
    am thinking of building a ruined part of a rail station ,just two walls for my latest dio any ideas what to use to carve bricks on to .
    thanks
    I have used 25mm thick insulating foam board it is about the right thickness for stone or brick walls and once you peel off the silver foil on the front and back of the board you can make the shapes or patterns in it very easily.
    scott
    • spanner570
      • 15402
      I use the smooth side of the polystyrene bases you get under a Pizza inside the box.
      • bazers
        • Oct 2013
        • 2611
        Thanks guys
        i read your artical on zulus spanner and thought the pizza base was a misprint,
        pizzas for dinner then.
        • spanner570
          • 15402
          Originally posted by \
          Thanks guysi read your artical on zulus spanner and thought the pizza base was a misprint,
          Nice one Barry, if you do go down the Pizza road, just make sure there is a disk of polystyrene in the box. Some are just packed in thin polythene and shoved in the box - no poly.!
          How you find out I really wouldn't know - other than quietly opening a box in the shop....which is of course, something us modellers would never dream of!!!!
          Good luck with your model, whatever material you choose.
          Ron
            • 18269
            sound damping foam for under flooring works well. probably tastes better than a freezer pizza as well. lol
