Cracked Conrete Road ?????
  • takeslousyphotos
    • Apr 2013
    • 3900
    Hi All,
    I'm looking to have a cracked concrete road for a dio........... Maybe with a few small potholes and patched up areas ...... But I have no idea where to start ???? .......... I thought about Tarmac. They stuff they sell for train layouts. But it looks too pristine and "black" .......any help or ideas would be appreciated.
    Peter
    You could use normal household filler for the road. or wetndry paper is also good you can paint both to the sort of shade you want.
    • eddiesolo
      • Jul 2013
      • 11193
      This is my side wall on the SW docking bay 94 dio I am doing, it is polystyrene with a coating of modellers fine powder mixed with PVA and applied with a lollipop stick, if you dry it quickly-I stuck it in front of my halogen heater and it steamed, you get this cracked effect.
      [ATTACH]102082.IPB[/ATTACH]
      Si
      • Alan 45
        • Nov 2012
        • 9833
        Have you thought about thin cork Peter ? It has a texture to it and cracks easy
        • takeslousyphotos
          • Apr 2013
          • 3900
          Thanks Fellas .............
          I like the finish on that Si ....... Perhaps I 'll give that a try. I suppose a hairdryer on hot will have a the same effect ......?????
          Alan, I have an old cork noticeboard kicking around at work ...I'll rip that apart and experiment a bit.
          • Gern
            • 9217
            How about fine grade sandpaper rather than wet and dry? At least it's a pale brown colour rather than dark grey so should liik more like concrete.
            • monica
              • Oct 2013
              • 15169
              or you can always pore a thing layer of plaster in the top of an ice cream lid,let dry,and you can bet your life if
              you try not to brake it it will brake,then set that down were you wont on top of a PVA,glue bed and just dont push right down leave uneven,
              as well i do like Si,cracked effect.
              • takeslousyphotos
                • Apr 2013
                • 3900
                I do like that idea Monica ........I think I'll give that a try...
                Peter
                • grumpa
                  • Jan 2015
                  • 6142
                  I'm a plaster guy too - mix with a bit of joint compound, this will slow drying time a bit and give you some time to work with it - put near heat source - when dry should have cracked nicely
                  • takeslousyphotos
                    • Apr 2013
                    • 3900
                    Thanks Jim......... I'm going to give the plaster a go......... If I get it right I'll post the results up on here.
                    Peter
                    • takeslousyphotos
                      • Apr 2013
                      • 3900
                      Well it's sitting in the oven right now cooking away a treat ............... Can't see any cracks yet . But I put some gauze bandage in the tray I used for a backing, so with a bit of luck I can crack it when it cools and it'll stay in one piece for gluing to the base...... fingers crossed......
                      Peter
                      • takeslousyphotos
                        • Apr 2013
                        • 3900
                        One very nice "Cracked Concrete" Road Surface ........... I'm proper pleased with that.......... and the gauze on the back is holding it all together. When it cools down I'll stick it on the base.
                        Thanks to everyone for your valuable help on this one......... It really is appreciated.
                        Peter[ATTACH]102201.IPB[/ATTACH]
                        • eddiesolo
                          • Jul 2013
                          • 11193
                          Looks just the job, nice one.
                          Si
                          • takeslousyphotos
                            • Apr 2013
                            • 3900
                            Si
                            A bit more cracked than I'd intended ............. But sometimes in life we just have to take what we are given Si ........... I've stuck it down to the base on a "bed of PVA" (as Monica put it) ...... tomorrow when it's hardened off properly I'll seal it with some thinned down PVA .......... Job done !
                            Peter
                            • eddiesolo
                              • Jul 2013
                              • 11193
                              Peter
                              I like it and think I will have a crack at this...the wife has just cleaned the oven so might as well mucky it up for her again.
                              Si
