Looks good Peter.
Cracked Conrete Road ?????
Originally posted by \I like it and think I will have a crack at this...the wife has just cleaned the oven so might as well mucky it up for her again.
SiComment
Originally posted by \Looks good Peter.Comment
Thanks Ian ............. I just have to get the couring right. I've been looking at some concreted areas here at work ....... and they are a great mixture of colour...... when most people thing of concrete they think it's grey, and I guess when it's new it pretty much is....... But there are other colours involved as well ....... particularly when it's dirty. Particularly in the cracks and potholes........
I think I'll start with white primer, then mist it in grey ........ and a brown wash....... and see where I go from there. Unless anyone has a better plan????
PeterComment
Peter, don't use your expensive spray paints!
Get some cheapo children's acrylic tube paints and try using a paint brush......just go over your concrete with grey or whatever colour you want. (no need to prime) Changing shade and colour slightly as you go. The paint will soak into the cracks naturally,and be a lot darker than the surface colour.
Using a brush gives a far better streaky surface variation in shade than an A.B. You will have noticed 'real' concrete tends to be ever so slightly different with each mix used...Then if you want, repeat the process with a slightly different shade.
Too often model 'concrete' is too bland and all the same shade....not like real stuff...as you've observed!Comment
Peter, I've just done this rough 3" square test piece to show how a brush does the texture, shading and fills cracks, whatever, as you apply the paint.
[ATTACH]102254.IPB[/ATTACH]
[ATTACH]102255.IPB[/ATTACH]
I hope this will be of some help.
Ron
Originally posted by \Peter, I've just done this rough 3" square test piece to show how a brush does the texture, shading and fills cracks, whatever, as you apply the paint.
[ATTACH]112340[/ATTACH]
[ATTACH]112341[/ATTACH]
Ron
PeterComment
Originally posted by \Peter you could get a tester pot of Dulux soft stone that gives a nice concrete colourComment
Originally posted by \Thanks Ron.......... I'll give that a go. I have some grey emulsion type paint in the garage. I guess that'll do the job thinned down a little ?????
Peter
PeterComment
Peter
Just watch how all the cracks, general scratches and imperfections become highlighted all on their own.....Some you won't have even noticed before you applied the paint!Comment
Originally posted by \I just had a thought Ron ........ I sealed it with PVA ...... So maybe I should have gone straight for paint instead ???
Peter
Not sure really, as I usually just slosh the paint on....no primer.
Give it a whirl, it should work and still flow into the cracks. Try a test corner first perhaps?
Try wiping the excess off with a cloth...It's only rough old concrete. Not summat from the Louvre! lol...
Later, try casting another piece and paint it direct.....One for the future!Comment
