Peter, I'll get this in before the 'master' reappears and puts his dippy in!
The reason I don't use sealer is because when I model concrete, bricks or stonework, I like to let the paint run where it wants...i.e., it can soak in and spread. It does take two or three coats. Each coat bringing out more features in the surface.
Whereas if the surface is sealed, the paint is confined and can't spread and soak in. Take a look at a real concrete crack and you will observe staining at the sides, this is the soaking and weathering effect you won't get if it is sealed beforehand.....
One final bit of advise..
If possible, I like to tilt the base at an angle and work from the top running the brush across the top and work down, side to side, using plenty of paint. Let it run where it wants to. Then lay the base flat and go over the whole thing just once....don't fiddle!! Rains and stains aren't fussy!
Right I'm off before he turns up again!!!!!
