Originally posted by \
Somewhere in North Africa
Cheers moni I'm glad you like him
Done some painting today [ATTACH]113937.IPB[/ATTACH]
[ATTACH]113938.IPB[/ATTACH]
next up is weathering and putting some bits on I've left off so I didn't knock off while weathering
Attached FilesComment
Originally posted by \Just been catching up with this one Alan, the jeeps look nice mate and the figures don't look to big in my mind, it was quite a snug vehicle really. Did you brush paint these Alan? What's your process?
Phil
Yes it's brush painted , my proccess is a simple one , paint the base coat , oil wash dry brush again in base coat if needed then dry brush in a dark grey along edges to give the impression of ware and tear then use an using a thin brush and put a small amount of oil paint on and dry brush that into corners and around detail and fade it out with a clean dry brush, then a couple of coats of matt clear varnish and it's done
It sounds like a lot of work but once you get the hang of it which isn't long you'll fly through it , just one thing when you add the oil paint make sure your base coats are completely dry of it can remove your base coats
I've now painted the Jerry cans[ATTACH]113949.IPB[/ATTACH]
Cheers moni
I did have a helping had with this jeep though as I had built the main body over a year ago but I lost interest in it and it sat on the shelf
Well I've managed to finish the first part of the weathering[ATTACH]114003.IPB[/ATTACH]
[ATTACH]114004.IPB[/ATTACH]
[ATTACH]114005.IPB[/ATTACH]
next up is the scuff marks and the bits of detail
Cheers moni
It's not a wash though , I've done a little tutorial telling you how to do it here
First part of the dio finished, both jeeps with drivers receiving orders from an officer
[ATTACH]114188.IPB[/ATTACH]
[ATTACH]114189.IPB[/ATTACH]
Might change tha positions a bit but this is roughly how it will look on the base
I've worked on the building over the last few days and got the outside painted
[ATTACH]114500.IPB[/ATTACH]
[ATTACH]114501.IPB[/ATTACH]
[ATTACH]114502.IPB[/ATTACH]
[ATTACH]114503.IPB[/ATTACH]
[ATTACH]114504.IPB[/ATTACH]
The top will have sandbagged mg posts so I haven't done much but dirtied it , rather harsh looking brown will fade as it dried giving it a more dusty look
