I have the germ of an idea for a diorama from around the Battle of the Buldge.
I got this after much searching but, sadly, it has a major moulding fault
This fault is a raised line running up the height of the front which has damaged the brick and stone detail. This is worse than it looks in the picture.
My first thought was to return it but it was the last one in stock so I decided to try and sort it. If all else fails, it will have ivy crawling up the wall to cover it
My first thought was to put a Sherman on the base but I fancied something a bit more compact and a bit different.
A quick search in the stash uncovered this which fits the bill perfectly. It will be moving ammunition and supplies rather than towing a gun which would not fit on the base, I want this to be quite compact.
Of course, it will need some figures and a dusting of snow so this is going to introduce me to some new techniques.
