Need some advice on building stadium seating. At the moment, I printed out on card and folded over. Ideally if I could find some L shaped plastic widgets. The seats are around 4mm wide.
Stadium advice on seating
GuestTags: None
Yeah. Did think about this, but the problem would be cutting, as I'd want individual seats. I was thinking of foam stick on pads, which can be purchased in 5mm squares. I'd have to paint them though.
OK the only other thing I can thick off but not sure how wide they are is the wooden coffee stirrers but might be a bit fiddly ÂComment
Cheers. But I'm not sure what you mean by just one cut. From what I see, I'd have to cut thousands to make the seats?Comment
Don't bother with seats and have it terraced.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Yeah. That would probably take a long time. I'm going to try 5mm stick on pads, one for the seat and one for the back to try and recreate. I'll have to paint them insitu. I've contacted some plastics companies to see if they can help. If not I'd just stick with the seats printed on card as in the photo.
Rickoshea, it's has to be all seating; damn Taylor ReportComment
