Hello everybody am starting a new diorama a airfix 1.24 mosquito, I need hope tho . Am thinking off doing it as a cut out so showing the inside off the wings body and tail so a lot off scratch building the frames any idea how to build the frames and Wht to do for the diorama thanks Steve
new dio a 1.24 mosquito
GuestTags: None
Not sure how a cut away will go in a diorama, but you can get quite a few add on sets for the big mossy these days, So I would go that rout. Open all the panels you can and get the gubbins to go inside the hatches and have a mantainace crew at work.
One way you might get your cut away in to a dio would be to show one being rebuilt/restored.
I only see one real problem and it is the same reason I have not bagged a 1/24 mossy. ITS HUGE! If you are also going for a diorama, to get any thing near workable you are looking at a base the size of a dinner table!
I saw some good photos on t'interweb yesterday, I will see if I can find them again.
Ian M -
That was quicker than I thought it would be.
Victoria Air Maintenance Ltd. - Total Repair, Overhaul and Major Rebuild Service ยป Projects The mossy project starts about half way down the page....
Ian MComment
Thanks Ian I know its a big kit but a lot of detail and. your right about the cut out its Going to be a lot off work and as for men around the plane working on it .I think every body done tht . I want to do some think diffrent and thanks for the link I will have a look now cheers SteveComment
And if I was doing a dio of the mosquito in a factor being assemble and I build a corner of the factor how high would I have to build the walls ?Comment
Originally posted by \Can u buy the mosquito in 1.32 ?
I hear rumors that A firm is working on a new 1/32 scale one, I think they where called XL Wings or something.
As for for the height of the walls, no idea! High enough that the aircraft can be there and room to lift it around in....?
Ian MComment
Sorry I thought I sent the first message wen I sent it . It come up I didnt so sent it again and now there two message sorryComment
hi can anyone find pics off a factory where mosquito was built so i have a idea wht am building thanksComment
I think the 1/32 Mosquito Ian is refering to is the one produced by Revell many years ago.I remember being given the kit for xmas sometime in the early 1970's.I wonder why Revell dont sell it anymore?.They still do the Beaufighter and ME110 in 1/32 and they came out round about the same time as the mossie.Comment
If you type either....Mosquito factory or Mosquito factory Hatfield, into Google images there are some good pictures on there.
Hope this is of some help.
RonComment
