new dio a 1.24 mosquito
    Thank you i will have a look. Cheers steve
      I fear that you will struggle with what you're looking for; the wings were built in one piece, wingtip to wingtip, with the top and bottom covered by sheets of plywood screwed into place (with hundreds of brass screws,) then covered with fabric, doped into place (by hand.) The fuselage was completely kitted out, in two halves (just like a model,) then the halves were joined, and also completely covered with fabric, leaving a cut-out, which fitted over the wings. There was only the radio hatch and crew access door, in the fuselage, and all of the wing access points were underneath, leaving only the engines accessible from above.
      Regarding 1/32, there are plans for a company, named Wings XL, to produce a 1/32 Mosquito, but there's no date fixed, so it's unlikely to appear before next year.
      Edgar
        Thanks i knew most of that but it will be nice to give it a shoot cheers steve
          Hit the buy it now button for this mossie, its in canada but cheap.............
          REVELL 1/32ND DEHAVILLAND MOSQUITO MKIV MODEL KIT.includes VAC clear parts | eBay
            Thanks ian. Will have a look
              • 18271
              Or this one but be quick, I might grab it ;-)
              Revell 1/32 OOP De Havilland Mosquito Mk IV #4746 1992 | eBay
              ​Ian
                i will let you have this one ... the one i am after is the one with 4 gun on the nose
                  All Revell 1/32nd Mossies have a glass nose ! Paragon Designs made a
                  resin aftermarket job but they are rare too but the can be found ......
                  GMAE3201 1:32 MOSQUITO FIGHTER BOMBER NOSE PARAGON | eBay
