Preserving real twigs/branches from plants.
  • AlanG
    • 6296
    A quick question to all you diorama guru's out there ( spanner570 maybe?). How would i go about preserving any twigs/branches i find suitable to use for trees/bushes in a diorama so that they don't deteriorate?
    You need John Race - 'Glycerin Man'.
    • AlanG
      • 6296
      Forgot to say it needs to be as cheap as possible. I'm skint lol
      • Andy Belsey
        • 887
        I don't treat mine with anything and have got away with it without problems.
        Andy
        • scottie3158
          • 14201
          • Holbeach
          with greenery mix glycerin available from any chemist for a few pounds and mix with warm water 50/50 thoroughly mix and allow to cool. I usually make two batches in old take away pots but any container with a lid is suitable. I mix will have the plain mix the other will have the mix with a few drops of green food colouring in this will help it keep the colour. Add the items you want to preserve and ensure they are covered and kept below the surface of the liquid. Allow then to soak for 24-48 hours. Then remove lay out on kitchen towel until dry. They can then be fixed using white glue or CA. HTH.
          You can then also use clear laquer or paint if you require.
          Small twigs I don't bother preserving.
          • AlanG
            • 6296
            Cheers guys. So basically i can either preserve or leave then. Just thinking about doing a dio with a tank (yes possibly a stug BattleshipBob lol). Never done a dio before so a world of firsts for me.
            • scottie3158
              • 14201
              • Holbeach
              Yes the twigs you can.
              • BattleshipBob
                • 6792
                • Bob
                • Cardiff
                Did i hear a Stug mentioned??
                • spanner570
                  • 15391
                  Hi Al'
                  Same as Andy.
                  I don't treat my stuff either.
                  • rtfoe
                    • 9078
                    I hang my roots and twigs to dry at least for a week then coat them with varnish before painting.
                    • AlanG
                      • 6296
                      Stug will have to wait Bob. I've just ordered a load of paints from John lol. Although i did see a cheap 1/35 Revell King tiger on evilbay. Not sure how good they are though
                      Sorry for the dumb question. But what type of varnish?
                      • rtfoe
                        • 9078
                        I use a rattle can varnish...a local brand probably gloss. I just realised it says Acrylic Lacquer on the can.
                        • JR
                          • May 2015
                          • 18273
                          No, it's ok Bob a false alarm. :flushed::crying::smiling5: Alan mearly mentioned he might.
                          Time for you meds I think :smiling2:
                          • JR
                            • May 2015
                            • 18273
                            Alan I've just seen this so rather late,
                            Paul Aka Scottie is spot on in his method.
                            As has been mentioned some people don't bother, the only drawback with that is that the items can dry out and become brittle. The glycerine mix does give an amount of flex in some pieces of material and stops the item from rotting .
                            There is another way of using sand ,dry of course and even salt, however I've not tried either of those .
                            I have some sea grass that was done 3 years ago and it's still plyable. Small roots like the bramble will last without any treatment for a number of years, above ground cuttings will eventually succumb and crumble .
                            • spanner570
                              • 15391
                              Oops!
                              I thought Alan just wanted to know how to preserve twigs and branches.
                              I really should get out my bus pass and go to specsavers - If I can see where the bit of plastic is of course!
