Air-to-air combat dio
    Cross-posted from UAMF, in case anyone also reads that forum...
    I've just acquired a 1/72 scale PZL P.11 off eBay, and am thinking about producing a diorama of it attacking a Stuka head-on over Poland in September '39.
    Has anyone any thoughts on this - in terms of damage to the Stuka but also of how to actually mount the aircraft in the right poses - would one of those two-kit Airfix bases do the trick or would I be looking at manufacturing something?
    And if anyone knows of any pics of something similar knocking around, I'll be glad to see them...
    in my experience, those airfix dogfight double stands are crap, i had one that would not even support the weight of the plane in the box it came with. clear perspex tube may be a better option for you or even a small length of 9mm copper pipe which is quite sturdy but can be bent any angle you like.
      Googling for some tips threw this up - and I use the phrase "threw up" advisedly.
      Make a military diorama of aircraft battling
      So what's a "Tiger" when it's at home? Well, apparently it's a Curtiss Hawk with "US ARMY" on the bottom and RAF roundels on top, which fires rockets out of its machine guns and can dive vertically with its undercarriage extended...
        Originally posted by \
        Clear perspex tube may be a better option for you or even a small length of 9mm copper pipe which is quite sturdy but can be bent any angle you like.
        I was wondering about something like this, actually...
        pillars & dowel rods : Cake Stuff
