Going underground: "BMP in Aleppo ll"
  • Steven
    • May 2018
    • 589
    #46
    Further pics still wip need to do some touching up on the black
    • Steven
      • May 2018
      • 589
      #47
      Good Afternoon Gents
      Had hoped to mont the balconies during my Autumn vacation but but decided to abandon that idea for the time being as mounting them will make for a very awkward build due to their angular shape, right now the front is lying nice and flat allowing to better fit the details and do general work on the weathering
      I have however worked abit on the shattered parts of the balconies adding rebar and the exposed concrete
      [IMG width="602px"]https://i.imgur.com/kWKKyeL.jpg[/IMG]
      [IMG width="690px"]https://i.imgur.com/dpwIaFg.jpg[/IMG]
      this one stil needs a bit work getting the area with tiles right is trickey
      [IMG width="464px"]https://i.imgur.com/jC4KXse.jpg[/IMG]
      smaller bits will attached to the rebar and be found scattered on the ground.
      mounted some cables and an AC unit started adding weathering by adding streaks - more on that tomorrow where the riveting topic sof sandbags and corrugated roofing also will be touched upon.....
      [IMG width="606px"]https://i.imgur.com/RxoU9nO.jpg[/IMG]
      • scottie3158
        • 14197
        • Holbeach
        #48
        Progressing very nicely mate.
        • Steven
          • May 2018
          • 589
          #49
          Thanks Paul
          aside from some pre -shading, I have been using Wilder's weathering Pencils exclusively on the facade and I quite like them, also I am working where the kids sleep ATM which makes anything emitting fumes a nog-go. Also, even though the surface has bee sealed with both the terrain - paste and poly filla, thesre are quite porous in nature and I do not dare using anything solvent - based on this...
          overdid it on the top section and will be deleting this but the sections underneath where the balconies will go (masked on the pics) seems to be warrenting some heavy streaks - I am using a mix of "streaking grime" and black
          [IMG width="674px"]https://i.imgur.com/4Avsrdk.jpg[/IMG][
          Rust....
          Sticking with odour -less techniques, i have been using diluted "oxy-grime" from the "U - Rust" set from Ammo applied by sponge on the Arcade roofing trying hard not to overdo it as rust is less prevalent in the Middle East, mind you, the average downpour in Aleppo ,Syria, during the winter and spring is skirting northern European standards, so a little rust on structures poorly maintained and exposed to the Elements, won't go amiss.
          [IMG width="656px"]https://i.imgur.com/dn1s2qF.jpg[/IMG]
          [HEADING=3]Making the ceiling of the arcade more interesting:[/HEADING]
          As not a whole will be seen of the cieling I did a light job of the weathering but I am thinking of adding a ceiling fan and a fluorescent tube - what do you think?
          [IMG width="441px"]https://i.imgur.com/46aZzdj.jpg[/IMG]
          they are not really visible but I have added mounting bolts
          [IMG width="623px"]https://i.imgur.com/MTvCqxP.jpg[/IMG]
          [HEADING=3]Sandbags:[/HEADING]
          The building is heavily fortified and sandbags abound - will be at the windows and the doorway in two layers- not much to say good old Milliput - painting them offwhite will test my steady hand with the airbrush and my patience masking the area around.....
          [IMG width="627px"]https://i.imgur.com/ul6HCtH.jpg[/IMG]
          close call on one of the bags near the firing slit
          [IMG width="878px"]https://i.imgur.com/N7wSOE3.jpg[/IMG]
          Alll for now
          • Neil Merryweather
            • Dec 2018
            • 5181
            • London
            #50
            Stunning stuff, inspirational!
              • 15641
              Impressive attention to detail. Very neat, realistic work.
              • Windy
                • May 2018
                • 379
                • Alex
                • Dorset
                #52
                Stunning work. That wriggly tin looks real.
                • Andy the Sheep
                  • Apr 2019
                  • 1864
                  • Andrea
                  • North Eastern Italy
                  #53
                  Ditto!
                  • Steven
                    • May 2018
                    • 589
                    #54
                    Thank you so much for the nice comments it really boosts my motivation
                    A mock - up of the Arcade sp far
                    • Steven
                      • May 2018
                      • 589
                      #55
                      Thanks for that kind words
                      Same method as with the corrugated roof used on the body of one of the signs on the front of the arcade
                      BTW I'm struggling with my DIY decal and is close to abandon the idea of having a shattered neon sign on the front altogether so the below might never be fixed to the arcade
                      • Steven
                        • May 2018
                        • 589
                        #56
                        Meanwhile construction of the building proper continue I have added the facade parts coated in pollifilla and concrete terrain paste which have been sanded
                        • Steven
                          • May 2018
                          • 589
                          #57
                          Done resting on my laurals from taking bronze at a recent modelshow
                          Building:
                          To my dismay I discovered that the upper balcony is not identical to the lower so I decided to make another
                          More details on this later
                          Archway:
                          Building flourescent lights not terribly difficult but I need a lot in this build so I recently ordered this set it's an old Verlinden set and some of the electrical installations are aged but the fluorescent bulbs are nice the two large ones will go on the roof smaller in one of two commercial signs on the facade of the archway
                          • scottie3158
                            • 14197
                            • Holbeach
                            #58
                            The great work continues to impress.
                            • Steven
                              • May 2018
                              • 589
                              #59
                              Thanks Scottie
                              Hello Chaps
                              Archway front signs
                              I have been struggling with the decals for the shattered commercial signs that will “adorn” the front of the Archway of the Arcade for weeks now – better quality decal paper and better varnish did the trick – the resulting quality of the print is still down to my crappy printer – I need a designated decal printer – please Santa, I have been a really good boy….. I guess the result is acceptable for a Weather – beaten battle damaged sign – second one still in production
                              Still need some finishing
                              The larger signs on the roofing. One is 90% done one is discarded due to being to large ti fit the scene awaiting arrival of new prints from MMA - this will be closer to the mortar hit on the top of the Archway and will display more Shrapnel damage - if you have tips on how to Ahieve this realistically - let me know - will also be posting this on the general forum is I can’t find any posts dealing with this – and oh not forgetting the internet….
                              • Steven
                                • May 2018
                                • 589
                                #60
                                Thanks Scottie
                                Hello Chaps
                                I have been struggling with the decals for the shattered commercial signs that will “adorn” the front of the Archway of the Arcade for weeks now – better quality decal paper and better varnish did the trick – the resulting quality of the print is still down to my crappy printer – I need a designated decal printer – please Santa, I have been a really good boy….. I guess the result is acceptable for a Weather – beaten battle damaged sign – 90% done one is discarded due to being to large ti fit the scene awaiting arrival of new prints from MMA - this will be closer to the mortar hit on the top of the Archway and will display more Shrapnel damage - if you have tips on how to Ahieve this realistically - let me know - will also be posting this on the general forum is I can’t find any posts dealing with this – and oh not forgetting the internet….
                                Archway front signs
                                [ATTACH=CONFIG]n1213204[/ATTACH]
                                [ATTACH=CONFIG]n1213205[/ATTACH]
