Cammo netting?
  • GerryW
    • Feb 2021
    • 1757
    Cammo netting?
    So what's the 'go-to' for cammo netting nowadays? Last time I was doing any amount of modelling, the 'usual' was a hairnet (Ena Sharples style!) - still got some sat in the old modelling box:flushed:
  • scottie3158
    • 14199
    • Holbeach
    Hi Gerry,
    Firstly welcome to the forum. Personally I use Boots own brand gauze swabs they are cheap and last for ages.(There are other brands available) Simply cut to size soak in diluted white glue then form it around where you want it and let it dry. I normally place a piece of cling film over the kit so it doesn't stick and it can be removed to paint when dry. HTH
    • GerryW
      • Feb 2021
      • 1757
      Hi Gerry,
      Thanks, will look at those - I don't reckon that hairnets are even produced nowadays!
      Though not too far out for 1/35 scaleClick image for larger version
      • Strenko J
        • May 2018
        • 752
        • Joe
        • Pittsburgh PA
        just like Paul...Gauze pad cut to size and white glue diluted of course is my go to.
          You can of course go the fancy route........... https://fieldsofglorymodels.co.uk/se...&type=product#
          • wasdale32
            • 1115
            • Mark
            Depends a lot on the period that you're trying to replicate - WW2 cam netting was fairly basic scrim netting with foliage or hessian strips tucked into it - that is well represented by the gauze already mentioned. Modern cam such as "Barracuda" tends to be die-cut fabric rather than netting - I found that a fair representation of modern cam can be done with garden "weed-block" which is a rubbery fabric with holes that can be stretched to expand the holes. I had a roll of the stuff left over from the garden. The effect can be seen below:
            • GerryW
              • Feb 2021
              • 1757
              Interesting - until I saw the size/price:smiling5:
              • GerryW
                • Feb 2021
                • 1757
                [ATTACH=CONFIG]n1144219[/ATTACH]
                Thanks, though probably more interested in the WWII period, always worth keeping it in mind:thumb2:
                • GerryW
                  • Feb 2021
                  • 1757
                  Wonder if you can still get 'sprout nets' from greengrocers?:thinking:
                  You can tell that I 'model on the cheap' :tongue-out:
