Deep snow?
  • GerryW
    • Feb 2021
    • 1757
    Deep snow?
    Still planning and trying to figure out a dio which is going to need deep snow (about the equivalent of 2 feet) and not sure how to get that sort of effect, so now asking the experts.
    Build it up like any other groundwork, with foam or whatever you prefer to use. Then, instead of covering it with a fairly coarse texture to replicate earth, cover it with something smooth and paint it white.
    • AlanG
      • 6296
      What scale is your diorama going to be? I've just bought some Precision Snow & Ice. Looks a great product. Check it out on Youtube
      • GerryW
        • Feb 2021
        • 1757
        Thanks Jakko :thumb2:
        It's basically going to be (ground) a house & garden with a hedge, so thinking about it, with no roof insulation - very little on roof, but need the hedge and garden fairly well covered with the path trodden down.
        Thanks Alan
        Going to be 1/72, so will need to be fairly fine stuff, I'll check them out on youtube, thanks!
          If the snow is very deep, there will also be on the roof of the house, even if that is heated and uninsulated, though not as much as on the ground, I suspect.
          • GerryW
            • Feb 2021
            • 1757
            What I was thinking - the house had facilities for fires in the 3 bedrooms, but with coal being rationed, possibly with only what little wood that could have been gathered locally - January 1940 was a cold one!
            • JR
              • May 2015
              • 18273
              I would build the ground work up with the likes of
              Being white it's best feature, plus it's very light weight , work it with a wet finger to make it smooth. Spray this with hair spray before applying the snow powder .For snow I use as Alan has suggested precision ice and snow. They have 2 sizes of snow for use with 1/72 and 1/35 and larger. Look on UTube for more tips .
              • GerryW
                • Feb 2021
                • 1757
                Thanks John, will be investigating that - and there I was thinking about using bicarbonate of soda or flour!
                • JR
                  • May 2015
                  • 18273
                  I'd looked at such thing Gerry, but apparently they have the chance of going off, or developing a yellow tinge !
                  • GerryW
                    • Feb 2021
                    • 1757
                    I did wonder if there would be a case of 'yellow snow' if I'd gone that route! :smiling2:
                    • Lee Drennen
                      • 7711
                      Gerry. JR. is the snow God. That’s why his hair is white lol
                        • 18891
                        Hi Gerry
                        Flour and baking powder will go yellow. Baking soda (bicarb) doesn’t. Baking soda and white glue makes a very good melting snow effect.
                        John is the snow god though, so follow his advice.....
                        • rtfoe
                          • 9073
                          I'd throw in a suggestion but can you believe a guy from the tropics? :tears-of-joy:
                          PS: I do have one or two suggestions having done snow dios.:smiling2:
                          • GerryW
                            • Feb 2021
                            • 1757
                            All suggestions taken on board and gratefully received - I've never done anything to represent snow (not even a drawing!) so even worse than my current project (as I've done a few pictures with mountain scenery, which I've been drawing on for that)
                            • rtfoe
                              • 9073
                              Okay here goes. I use plaster of paris for my snow. It cures and hardens very fast so the method to create smooth snow that has settled and slightly melted on the top by the sunrays I would add more water to the mix until it is pourable and pour it over the surface I want. It immediately starts to stiffen as you pour so you can build up in layers. It's good for tops of walls and hedges as well as stream banks. Here's a shot of part of the dio I made...
                              I work in 1/35 scale but I think you can dilute the mix further and apply with a small syringe. Hope the images help.
