Concrete effects 1/72?
  • GerryW
    • Feb 2021
    • 1757
    Thinking ahead about my next planned project (been on 'simmer' for ages!) going to need to do a house with 'pebble-dash' walls (not needing to age it, as it'd only been built less than 10 years) obviously, the pebbles were of varying colours and sizes (max being about half an inch), and completely random patterns.
    Any suggestions for getting the right effect?
    My initial thoughts are 'flicked' paint brush and devil take the texture.
    In 1:72, you’d barely see the actual texture. I think I’d paint it like you suggest too: (tooth)brush with paint and scrape along it with something to fling the paint off onto the building. You don’t have much to lose by trying it out on one wall, I’d say — if it fails, repaint?
    • Gern
      • 9209
      Couldn't you mix some fine sand/dust in your paint? I'm also sure I've seen adverts for textured paint, though I can't remember who makes it.
      • spanner570
        • 15377
        Interesting question and good suggestions.
        I've just had a 'play' with various implements :flushed:
        I've come up with this.
        I used a wire brush and stippled the building wall. Then washed on some acrylic paint.
        Cheers.
        Ron
        • GerryW
          • Feb 2021
          • 1757
          Dulux and ICI make them but yes, can do that - friend once painted a motorbike (Russian 350 'Planeta' or 'Jupiter') using paint mixed with talc
          [ATTACH=CONFIG]n1152000[/ATTACH]
          Cheers.
          Ron
          That's a great result!:thumb2: Standard (welding) wire brush?
          Looking very similar to what I'll have to do - even to the few courses of bricks at the bottom!
            • 18882
            Depends upon which type of pebbledash you are trying to replicate Gerry.
            Ron’s approach will work for this finish....
            Yours and Jakkos approach should work for this finish.
            The only other approach I can think of is to use an appropriate grade sand paper as a finish to the wall and paint (dry brush and stipple for the colouring) to suit. Can’t help thinking that it’s a bit of a faff though, so I’d go with one of the two above.
            • spanner570
              • 15377
              Gerry. I don't know what size wire a standard welding brush has. :upside: I just used one of a pack I bought from a pound shop!
              Keep in mind, my approach would obviously work for any sort of colouring too, so there :tongue-out3:
              Isn't this forum great? A call for help and the Cavalry comes storming over the hill to help......
              General George Armstrong Custer June 26, 1876 (Full of arras)
              • GerryW
                • Feb 2021
                • 1757
                [ATTACH=CONFIG]n1152004[/ATTACH]
                [ATTACH=CONFIG]n1152005[/ATTACH]
                See what you mean, your top photo is how it looks after being painted, it's going to have to be like the bottom picture
                • GerryW
                  • Feb 2021
                  • 1757
                  Sounds like my sort of wire brush! :thumb2: Mine are all from either Wilkinsons or car boot sales
                  • spanner570
                    • 15377
                    This has gripped me!
                    To try and be of more help, I've had a couple more goes to see if it can be coloured using a wire brush for the initial texture.
                    Bearing in mind the model will probably be viewed from a scale distance, individual colours in the pebble dash will never be seen and be more 'blurred', so I've had a couple of goes at the wall again.
                    Keep in mind the picture is way, way to close for 1/72.
                    Anyway, enough from me. Just try all the excellent methods suggested.
                    I look forward to the actual build.
                    Ron
                    • GerryW
                      • Feb 2021
                      • 1757
                      [ATTACH=CONFIG]n1152008[/ATTACH]
                      Ron
                      That's a great effect, now wondering if I'll be able to get similar :tongue-out3:
                      I'll give all of them a go, and see what I get - take it that it's foam board that you're using Ron?
                      • spanner570
                        • 15377
                        Sorry Gerry, I should have mentioned, yes, it is foam board.
                        Of course you will get similar. No question. :thumb2:
                        Good luck whichever way you jump......And make sure you have fun doing it!
                        • GerryW
                          • Feb 2021
                          • 1757
                          Daresay that I'll run up against something that will make me think "What am I doing!" :tears-of-joy:
                          • Neil Merryweather
                            • Dec 2018
                            • 5181
                            • London
                            personally I would use spray cans in 3 or 4 colours, sprayed from a distance (flat) for a 'speckle' finish, then a hefty coat of matt lacquer quick before all the dots of paint fall off- you will even have the texture
                            • GerryW
                              • Feb 2021
                              • 1757
                              That's an idea, though I'm not that good with spray cans - usually fairly grotty results. But definitely worth bearing in mind.
