Explosions
  • Dulux
    • Jan 2022
    • 73
    Explosions
    Hi Guys,
    whilst looking at members dioramas (ahem) and YouTube videos it seems that creating believable explosions seems incredibly difficult and time consuming. Has anyone tried and been successful?
  • JR
    • May 2015
    • 18273
    Hi Steven , I've had a go at the doing rockets in launch see Aeroplast BM 13-24 Katyusha in 1/35 scale.
    It was tricky but enjoyable . You need to convey the sudden movement and the explosion.
    Like you I've seen a few on U Tube , have you an idea to build one ?
      • 18901
      Not an easy thing to model I would think. The problem is the airy nat of the beast so you can’t use solids. I’ve seen a couple of successful attempts, of which John’s has made at least two. The rockets was his most recent, but he also did a T34 crashing through a wall that used similar ideas of flying debris very successfully. I’m sure John will give you pointers, but you may have to look around a bit to find out how to make other effects.
      • Mark1
        • Apr 2021
        • 4156
        Some great tutorials onlineClick image for larger version
          • 15681
          Hi Steven
          Explosions are indeed very hard to model. John is too modest to put a link to his excellent Katyusha build so I will. HERE
            • 18266
            The big question is what do you want to explode?
            Water explosions are more simple its water and foam which can be done with glass clears silicon and paint.
            It gets a lot harder when its hot burning gasses and smoke. You are for all intent trying to model air.
              • 18266
              Found this that shows that its not impossible and look pretty good.
              • Dulux
                • Jan 2022
                • 73
                Thankyou Ian
                • adt70hk
                  • Sep 2019
                  • 10406
                  Interesting!
                  • Dulux
                    • Jan 2022
                    • 73
                    This guys “explosion” work is incredible
                    • JR
                      • May 2015
                      • 18273
                      Food for thought there alright .It's a fascinating subject to say the least . Now where are those matches !
                      • rtfoe
                        • 9076
                        Have met this guy personally and seen his builds up close and they're good. Works best with LED light's on.
