How I Build Dioramas in 1/16th.
    The front panel! Putting the front panel back together for the last time.I have taken a series of pics showing how to take this thing apart and put it back together.It is surprisingly easy if you know how .The landscaping,modules ,hangar walls,roof and rafters right down to the hangar floor can be taken apart in half an
    hour and put back together in about an hour.(it always takes longer)I would recommend to anyone building a large diorama that you take the extra time to make it easily taken apart.
    I want to put together a picture package for the museum as I believe that in this case a pic is worth a thousand words.
    The first pic shows the front area completely taken apart.The next few will show how to put it all back together again.
    These pics are all located in my sub-album "Construction dio3".
      I am nearing the end of the Jenny diorama and probably have about 2 weeks building time to completion of the project.I have decided to go back and re-visit a project that I thought that I had finished 7 years ago.I have learned a lot about dioramas since then and the piece now looks unfinished to me now.
      I am planning do the exterior landscaping and add another Albatros D.Va airplane as a basketcase being robbed of parts.I will post some pics here every few days but for an in-depth everyday update please see :
      Welcome to The Aerodrome - Aces and Aircraft of World War I
      See Forums,How I build dioramas......
      Cheers! John.
                The final positioning of Fritz will depend upon what looks best when the wrecked airplane is finished.The Albatros is broken at the cockpit seat area with the pilots seat belts hanging out.Having Fritz looking directly at this area may help in understanding the storyline for the average viewer.These little things can be so helpful in getting your story across ,which is after all the whole point in doing a diorama.It is sometimes quite difficult to find the balance between subtlety and the obvious.Too obvious and the whole thing looks contrived ,too subtle and the viewer misses the point.Usually subtlety is the way to go as the impact on the viewer is greater once it is discovered.In this case a lot depends upon the knowledge of the viewer,WW1 fans will get it right away but then again the relationship between dog and man is well known to the general viewer.Anyway I still have a while to think about it.
                  looks great.
                      Diorama Book
                      Here is a great opportunity to download for free a great book on diorama making.My modeling bud Ken Hamilton wrote this book years ago and it is now out of print.The original book has recently sold on ebay for 100's of bucks.
                      mercman51/DIO Book - Photobucket - Video and Image Hosting
                      Enjoy! Cheers John.
                        Research pictures needed. After thinking about it for awhile,I plan to build the fuselage and wings pretty much like I built the others.Because the fuselage is split in two the only thing holding the two halves together are the control wires.Therefore the fuselage will be built initially in one piece,broken and then bend.How much of the plywood covering forward of the cockpit area that I will do will depend on the amount of fire damage that will be shown.The fire would have to be large enough to flash burn the fabric off the wings but not large enough to consume the complete engine area.If the accident occurred at the airfield there would have been an attempt to rescue the pilot ,which would necessitate the use of some type of fire fighting equipment or other to subdue the flames during the rescue .By the look of the wreckage he was killed by blunt force trauma or G forces and not by fire.
                        The wings will be built as usual with damage added later.
                        The aft half of the fuselage will require that a lot of the plywood covering be shown .The tails planes would mostly be stress damage.
                        If anyone has knowledge of any pictures of wood and fabric airplanes ,old or new ,that have suffered this kind of damage ,please advise.
                        __________________
                        It has been said that the difference between a "pilot" and an "aviator" is that a pilot is a technician,and an aviator is an artist in love with flight.
                            Take a look over on:
                            Vint. Airplanes - ScaleMotorcars
                            for a couple of Camels and a Jenny build.
