Slow progress.... Thank goodness I only dry fit everything first!
When I modified the angle of attack of the wings in relation to the level ground,that also altered the undercarriage and the rear wheels required clearance of the frame.At first I attempted to change the angle of the struts that support the nose wheel by moving a fitting at the rear of the engine bearer.Darn thing wouldn't move so I had to take everything apart again and in the process broke a few ribs off and cracked one of the engine supports.
I finally was able to unjam the fitting and put it all back together and now the nose wheel beam seems to be at the right angle.
