How I Build Dioramas in 1/16th.
When the measurements are done it is time to start cutting in with the Xacto knife.I started with what I call the dining room window which is the largest on the back facade.
Keeping your xacto (new blade,change often) 90 degs to the surface cut into the foam board.I do this freehand and make a couple of passes until it is cut all the way through.At this stage I don't try to be too exact as the foamboard is soft and easily damaged.Put another piece of foam board behind the cutout and trace the perimeter of the window.Cut this piece out as well and line it up and glue it to the back creating a double thickness.This will allow for a secure surface for our window frame pieces and add a more realistic look to the thickness of the wall.When dry start fitting your frame pieces,do not glue for now but make a tight fit.I cut mine slightly oversize and fit and sand,fit and sand until they fit snugly .Get out a small square and adjust the foamboard until the frames fit 90deg to each other.
It is time consuming to do but I thank my lucky stars that I am only doing a plain outdoor facade and not your typical Victorian moldings that you would find on the inside.Comment
My Victorian Row House.
After a lot of research the following measurements seem to be consistent with a typical North American Victorian row house.From the lower level floor to the upper level ceiling is about 21 feet 6 inches.
The top of the piece of cardboard at the bottom of the foam board represents the top of the exterior boardwalk.There are two rows of blocks to the top of the foundation,a 2" cap strip and 2"X10" joists to the lower level floor.From floor to window sill is 30"and from floor to ceiling is 10feet.I have allowed 18" between the ceiling to the top of the upper floor level for joists,plaster ceiling, sub-floor and floor.Then another 30" to the upper window sill and again 10 feet to the ceiling.(Victorian ceilings were high)
The upper rooms are 12 feet in width to their center lines ,the actual room size would be less due to studs,walls etc...The lower levels widths are 12 feet for the dining room and about 10 for the kitchen ,the rest is the 30" wide door and storage area,the overall width is about 30 feet.Above the door is the bathroom so that the run of the plumbing is consistent with the kitchen area.
The doors and windows are tall and narrow to allow for indoor/outdoor air circulation.
The external roof line has yet to be established but it is usually a little above the upper window.
Please advise me if you guys notice anything obviously wrong with the measurements.Comment
The outside window sill is made from a piece of wood ,covered on three sides with glue and then sprinkled with very fine sand.The window frame I will paint an off-white and the bricks red or red-orange like in Victorian days.
When finished, I plan to treat the facade like a canvas and have some fun using acrylics,pastels,brush and airbrush to see what I can come up with. It will have to be subtle though not to compete with the main subject for attention.I want the viewer to first see the airplane,then the storyline and later pick out the details in the diorama.This is a large diorama and I have thought at times of cutting it back a bit, and probably would have if I hadn't built a 1/48 mock-up to keep me on track.I could really stop with just the one backyard and tell the basic story but I feel that by including the other backyards it will convey a sense of the builders priorities and enthusiasm for his airplane.His messy yard as opposed to his neighbors well kept grass and garden .I think that it will be springtime before all the flowers come out as I want to keep this aspect of the story subtle as well.
I also like the stepped down effect as if the row houses were built on the side of a hill as it helps to distract the eye from all the 90 deg angles.Also the piece will be placed at an angle to the base which will better allow me to put the airplane straight on as in the picture.Comment
I love this pic!( I know only a modeler could get excited about bricks) Anyway,it gives you a great palette of brick colors to work with and the wall itself is so very interesting.
I can see an artist getting lost forever in this detail , being able to practice every technique in the book.It will surely be a case of knowing when to stop.By comparison modern brick walls are so very boring.
I don't yet have any idea of how to achieve that rough cement grout work look but I am working on it.I think my challenge will be to restrain myself and not to make my wall too old looking.
I love the way Andi builds a history into his brick walls but I wonder if that would be appropriate here.The row houses in my reference picture look fairly new in 1913 and the residents fairly well off ,judging by the way the lady with the dog is dressed and the fact that our early EAA type could even afford all the materials to build his airplane.
I can hardly wait to start the painting of this piece .It is as close to 2D picture painting that a 3D guy can get....Comment
It has occurred to me that maybe I am going down the wrong path here.I am basically trying to represent what was a fairly new building in 1913.I look around my neighborhood at the brick structures after 20-30 or even 50 years and the bricks still look almost new.Maybe it would be a mistake to radically age my brick wall or try to build too much history into it.I love Andi's wonderful work but it may not be appropriate as as an example for which was a fairly new structure in 1913.
When to stop? What to leave in and what to leave out?Comment
Man I wish I had a camera lens that didn't create so much distortion.Anyway,here is where I am so far.The upper right bricks above the sill are as dark as I plan to go.The lower right is a little lighter and to the left of that lighter still.I have used JoSonja acrylic gouache paint.It is their Gold Oxide straight out of the tube, mixed only with plain tap water to a consistency of 5% milk.You could thin it out to about 2% but that is not necessary here as my base color is quite dark.The key here is to not get too dark too quickly,it is better to err on the side of leaving it too light and then darken individual bricks to the shade you prefer.(like the bricks you see on the left in the pic)You want contrast between individual bricks.I have always worked from light to dark to take advantage of the transparency factor afforded by gouache acrylics.It can be a little time consuming painting individual bricks darker but it saves trying to lighten them later.
When putting on your first coat be sure to paint the white brick edges that have not been already colored with a small round brush.Don't worry about getting it on the foam board as it has a surface that does not readily absorbed the paint, which is a real advantage here.(saves you having to grout the spaces between the brick) Any space that remains too white can be dealt with by applying a second watery coat.
The reason that I do the spaces now is if your do it later the edges may turn out too dark and spoil your work.
Pick a shade of color that you like as your base coat (which will end up being the lightest value on the wall)and randomly darken the rest until you are happy.Don't go too dark right away as acrylics will darken naturally as they dry,much like house paint.In fact I will let mine dry over night and do the finishing touches the following day.
If you plan to do dry brushing now would be the time to do so,I haven't yet decided myself. I may just weather them by flicking on some crud using my toothbrush technique and then use pastels to finish.So far I am happy with the result,I think that it looks like a 20-30 year old wall.Comment
The grey stone blocks where given the 5% milk treatment using JoSonja gouache acrylic.I used their Nimbus Grey mixed with a touch of Raw Umber and water.I darkened down the seams using the same mix and a small round brush.Try not to get too much on the face of the stone.
I really like this textured watercolor paper when using thin coats ,as it almost eliminates the need for dry brushing.Remember however one heavy coat and your in trouble.Not all is lost however ,as you can still dry brush the texture back if need be ,using a lighter tint of the same color.This is an example of the great versatility of acrylics.
The grey stones still need a little pastel shading and some crud along the bottom.
I would suggest to those who don't want to go to all this effort to make a brick wall ,if you think it looks good enough for your purposes especially in the smaller scales,when I am finished you could make a copy of the wall and then use photobucket to play with the colors and adjust it to any scale you want.Have fun!
Note: if you want a great tutorial on making scratchbuilt cars or aircraft in brass see my modeling bud Ken Foran's thread over on SMC.He is the best!
Scalemotorcars
Look under Large Scale Cars in the Forum.Comment
