The copper fuel tank is not in its final position but has been lowered to rest on the engine support beam.I left the tank fitting in a unusual place on the tube to indicate this.The fuel tank can easily be positioned higher, to its final gravity feed position ,when all the fittings etc ... are installed.(after he returns from the war)
The prop will not be installed because something as valuable as that (if he even had one)would not be left outside.
Next?
Next?
