Scammell Tank Transporter And Sherman Tank
    Im making a diorama to go with a scammel tank transporter and sherman tank. I've started the base but it will take a while to finish.
    Here are some pics of the base so far.
    I made the Shape of the rock faces out of oasis foam (flower arrangement foam) This will reduce the overall weight because i have to put so much papier mache on it to cover the base and make the right terrain. The White plaster of paris square is the base of what will be a blown up german gun emplacement being used by the british.
    [ATTACH]18707.IPB[/ATTACH]
    [ATTACH]18708.IPB[/ATTACH]
    [ATTACH]18709.IPB[/ATTACH]
    [ATTACH]18710.IPB[/ATTACH]
    [ATTACH]18711.IPB[/ATTACH]
    [ATTACH]18712.IPB[/ATTACH]
      I totally forgot to add pictures of the models so here they are.
      I get really annoyed when people say to spend around £10 on pigments for weathering vehicles so I was experimenting with some ideas and then i thought whats better to make mud than mud. So i went and got some mud out of the garden and added some water and then I simply just splashed it on. Its definitely a lot cheaper. The 5.5" gun will be getting set up in the emplacement while the transporter drives through carrying the Sherman.
      [ATTACH]18713.IPB[/ATTACH]
      [ATTACH]18714.IPB[/ATTACH]
      [ATTACH]18715.IPB[/ATTACH]
        Looking good so far!
        Using real mud is a good cheap way of doing things, however the application is a little on the heavy side.
        For the mud to have splashed that high over a real vehicle it would had to have been travelling at unrealistic speeds.
        The Scammel may have splashes onto the roof and engine cover, but they would be minimal.
        Try flicking the mud with a toothbrush or similar from various distances. Oh and turn the model upside down and spray from underneath! It will be concentrated underneath.
        Have fun!
          Thanks for the tips, I especially like the toothbrush one. I'll try it. But great minds do think alike sometimes, I've already done the underside of the model.And about the roof, I think your right. I went a little overboard with the mud. I'll try and get some more pictures on to show where the road will be.
            I've decided to change the 5.5" gun to a mortar crew, so here are some more pictures o the road, bunker, bridge and mortar.
            [ATTACH]18757.IPB[/ATTACH]
            [ATTACH]18758.IPB[/ATTACH]
            [ATTACH]18759.IPB[/ATTACH]
            [ATTACH]18760.IPB[/ATTACH]
              Ive decided to change the 5.5" gun to a mortar crew because the 5.5" gun would be facing the wrong way, so here are 2 more pictures with the mortar crew.
              [ATTACH]18783.IPB[/ATTACH]
              [ATTACH]18784.IPB[/ATTACH]
                The bottom rockface is now completely covered and i have added a trunk to which branches will be attached. Ive changed the design of the bridge and once I finished building it I mixed a matt brown enamel with the same amount of thinner then added a small drop of oil to help the mixture soak into the wood and bring out the woods markings. I have now begun to build up the rock face that the bunker is enclosed in and the ground sloping down from the roads.
                [ATTACH]18991.IPB[/ATTACH]
                [ATTACH]18992.IPB[/ATTACH]
                [ATTACH]18993.IPB[/ATTACH]
                [ATTACH]18994.IPB[/ATTACH]
                [ATTACH]18995.IPB[/ATTACH]
                  Looking good mate. It is hard for me to imagine the final effect so i am realy keen to see this project progress.
                  Andy
                    Looking good mate. It is hard for me to imagine the final effect so i am realy keen to see this project progress.Andy
                    Thanks for the kind words but I hope your not expecting too much as it is my first attempt at a dio.
                    Tom
                      Thanks for the kind words but I hope your not expecting too much as it is my first attempt at a dio.Tom
                      As you know from my Jug project mate... that this was my first also. I just put all of my heart and passion into it and it came out great, i think. I'm sure to will do the same. We can only get better as we progress mate.
                      Well done so far.
                      Andy
                        As you know from my Jug project mate... that this was my first also. I just put all of my heart and passion into it and it came out great, i think. I'm sure to will do the same. We can only get better as we progress mate.Well done so far.
                        Andy
                        Thanks mate
                        I'll start believing in what im doing and try my hardest to make it look good. (and by the way the jug does look great.)
                          Thanks mateI'll start believing in what im doing and try my hardest to make it look good. (and by the way the jug does look great.)
                          Thanks for the comment Tom. What i do is take my time and consentrate on one area at a time. See the finished area in your mind ignor any other part. You will know if it is going to look right or not, be happy with it before moving to another area. You find if you flash over everything, when it is finshed and you stand back, everything that isnt right will stand out and you will never be happy with it. It is alway easier to rectify bits and peices before you get to paint.
                          Take your time and enjoy it.
                          Andy
                            Thanks Andy.
                            It makes alot more sense than just rushing into parts when others are not complete. You always seem to help.
                            Tom
                              Thanks Andy.It makes alot more sense than just rushing into parts when others are not complete. You always seem to help.
                              Tom
                              Im sure you will do a good job mate. Its time we saw some more pics Tom. Have you got any mate.
                              Im glad that i can help, i have never built a dio either, but if you put your mind to it and take your time, you can do anything that you want. Remember it is all in the mind, see it build it. Atrists that paint without a subject are a prime example, they see every detail in their mind and then put it to canvas, starting with the back ground and then working forward in layers. Exactly what you want to do, see your landscape from a flat plane and build up each little section and then move to the next. If you break your image down into sections, say a grid of 6 and work on each grid area, blending one into the next, you will see the scale really come to life. So instead of building 1 dio you are now building 6 small ones. Hope this info helps and isnt a load of woffle to you mate.
                              Andy
