Right i've heard alot of people mentioning that when attaching leaves to a tree that they do it by spraying a water/pva glue mixture. Just want to know what do you use to spray said solution and how do you clean it out afterwards?
Spraying pva glue
wouldn't Tamiya thinner clean it out .it is strong . I know its not a cleaning product put its only pva glue cheers Steven -
You can get cans of spray glue from Poundshops. I just mix PVA glue with water & apply it with a brush.
I wouldn't try it through an airbrush, I'd be too worried about clogging it up!
PatrickComment
If you want to risk an airbrush at it you MIGHT get away with cleaning it out with loads of water then a good reamer like rinse.
However, if you have an art shop nearby, you have a couple of better options. Either buy a spray tin of glue, mounting glue type of thing, or ask if they have a mouth sprayer for fixatives. Its two tubes fixed at a 90deg angle a thin one that goes in the liquid and a thicker one you blow through. You could probably make one out of a couple of bits of brass tube, try with 3mm for the thin on and 5mm for the blow tube.
It works the same as a single action airbrush.
Ian MComment
you could try one of the cheapo pound type shops and pick up a plant mister/sprayer, i got one about three weeks ago for doing the houseplants and have already nicked it for modelling room.i use lots of pva in my work and would not like to risk it going off in an airbrush,it would rinse out easily with water but how many times have we all forgotten to clean out the airbrush straight away or been called away to do something.Comment
Like Patrick, I use a brush for trees and scenery but to seal a surface i use an old kitchen cleaner/disinfectant squirty bottle (some even have twistable nossels for spray and stream which is handy)Comment
Allyne. If you do not have any luck try Cow Gum. Why the name I have no idea.
We was used it in architecture for constructing models & mounting drawings & was perfect. A good adhesive while still soft & you can reposition. If it gets on anything by accident it will roll off without leaving any marks. Now that strikes a cord must try it as a masking agent !
PS Came then in a tube but I bet they also do it as a spray now.Comment
In the architectural models Allyne, we made, we used twigs from trees & shrubs. For foliage we used a variety of different sponges & cotton wool. They looked after a bit of artistic work very real.
God that seems years ago now.
LaurieComment
Al, get into the garden or woodland, find some ivy & pull it up ( wear gloves! )
Trim the root system, wash the excess dirt off & pop it in the microwave for a minute to kill any bugs.
Then brush with a PVA & water mix & sprinkle with dried herb leaves. I use mixed herbs or oregano. This makes excellent foliage & would work for trees too.
I'll be making one this week so I'll post pics if you like.
PatrickComment
Another good source for trees for diorama's is the hedges around the garden. Box hedges are best.... Great fir trees can be made from the dead flowers from a butterfly bush. (budlia?) bash the dead brown flowers off, roll them around in some thinned PVA then in a tray of that faux grass stuff.
Ian MComment
