Wall filler and Klear
  • AlanG
    • 6296
    I'm designing a dio at the moment and wanted to use wall filler for something. Was just wondering if i can use Klear (Future) to seal the filler after it has dried?
    Anyone know?
    cannot see why not. May take a few coats though as plaster soaks everything up like a very thirsty thing. I would use watered down, not too thin, PVA as it gives a great surface to then stick the scatter material to. However, Klear would be best for the finished item but remember it is glossy so a matt spray would be required.
      Hi flounder , Graham has made some good points , being an ex-decorator filler can be a pain to seal , anything water based will just get sucked in leaving it patchy no matter how many coats you give it , if it was me I would give it 2 coats of oil based or enamel paint , when in the trade we used to cover filler with oil based undercoat to get a top finnish .
      Hope this helps
      Richy.
        Fen that's your answer to everything today! Good advice tho. You too Richy, you the man.
          You wouldn't want to eat my iced buns Tony lol
          • AlanG
            • 6296
            Cheers guys. Gonna have to think about this one then.
            • AlanG
              • 6296
              Cheers for the info Graham. I'm not actually going to be sticking scatter to it and i need the surface to look glossy hence why i asked about klear. But if the pva gives a glossy finish then that might work.
              Can pva be painted over with enamels/acrylics?
                Not only can PVA be painted over but it can have acrylic paint mixed into it to colour it.
                • AlanG
                  • 6296
                  oooo now that would help alot. Cheers (again) Graham
