From the beginner's sand questions I've already posed you may be aware that I have a desert dio in the offing. It should be something like the attached piccy.
I started with a couple of 1/72 aircraft as I figured that I knew how to do them. Here they are,nearly done. The sharp eyed will spot the missing swastikas,they are on order as I didn't fancy making such tiny masks. There is also a bit of staining etc to do.
Fortunately,financially,though not for modelling, I shall be working away for the next 11-12 weeks so I'll be away from the bench. I'll still be checking in when ever I can and hereby solemnly promise that this dio will be done!
The Storch, from Academy,is a gem of a kit. I found it a bit fiddly in this scale (all those struts and the canopy comes in six seperate clear parts) but lovely fit.
The Kittyhawk,from Airfix, is obviously from a different era but still looks like a Kittyhawk once built. I copied the non-standard camo on the nose as I know this machine was previously with 112 Sqn RAF and had a shark mouth which has been sprayed over at an MU.
[ATTACH]23691.IPB[/ATTACH]
[ATTACH]23692.IPB[/ATTACH]
[ATTACH]23694.IPB[/ATTACH]
