Blood Effect
    Blood Effect
    Hi All
    Been thinking about a medi unit dio, I have been trying to create the blood effect, and not the red paint effect, been experimenting to try and get that coagulated oldish blood look.
    I would like to know if this effect would pass, and also what do you guys use to simulate blood, and any tips you may have.
    Thanks for reading.
  • stona
    • Jul 2008
    • 9889
    Looks good. Maybe a little darker,in my thankfully limited experience only very fresh blood is really red. How did you get that spatter?
      Thanks for the input Steve, I will attempt to darken it, I know what you mean, more coagulated. The blood splatter was created by dipping a brush in the blood brew and touching the crown on the airbrush, then just fire it at the target.
      • tr1ckey66
        • Mar 2009
        • 3592
        Looks great Ray - may have to borrow that technique at some stage.
        I agree with Steve though - a touch darker.
        Paul
          Okay guys took on board what you said, added a bit more black oil paint to the mix, am I getting closer?.
          Thanks all for looking.
          • tr1ckey66
            • Mar 2009
            • 3592
            Spot on!
            ...STRETCHER BEARER! (or whatever the translation is in German)
            Paul
            ps. Do you have any work to show us? You seem very knowledgeable and I'd love to see some examples.
            pps. Keep the tips coming they are excellent
              Ray, as Paul said "spot on' , looks very realistic. If you want to see real blood and body parts there is a site called rotten.com, not for the faint hearted but shows real gunshot wounds and ballistic effects on bodys as well as other weird and gory stuff. DEFIANTLY NOT FOR THE SQUEAMISH.
              Regards
              darren
                • 18271
                Splatter pattern is good but if he is just laying down bleeding, would there be spatter?
                As others have mentioned fresh blood is pretty bright or really dark, depends where he was shot. Blood from a liver shot will be so dark it would apper black on most other surfaces other than white.
                Old blood stains would be hedging towards brown dried blood would be a sort of deep red. The most important thing to remeber is gravity. Blood runs down hill. A small amount of wicking will of course show where fabric will absorbe the blood and spread it outwards from the wound.
                Hope that is of some help.
                  Thanks for the input and kind words, nice to know im getting there.
                  Thanks Paul, alas my knowledge is just paint related im sorry to say, worked with colours and colour matching most of my life, this forum has all the knowledge you need.
                  Rough old site Darren, but some good blood pics to use as referrence.Thanks for the input.
                  Nearly forgot, the blood mix is Tamiya Clear Red, then keep touching it with a brush dipped in Black oil paint wash.
                  You can apply this to bandages also on your models, let the blood mix set and do a very light burnt sienna wash on the outline of your blood stain.
                    Thanks for the info Ian, everything helps, much appreciated.The splatter was a test thing as I wanted to know how it would dry, going to use it up a wall, I fancy the idea of the medics in a building, with another building opposite with a Russian sniper in it.
                    • PJP
                      • Feb 2010
                      • 192
                      30 odd years of dealing with bloodstained people, and the last one looks good to me.
                      Shot or badly damaged people bleed from arteries and veins at the same time so it tends to be darker red anyway.
                      A big artery can send blood up to 20 feet until the pressure drops and blood mixed with water needs a surprising amount of water before it loses colour. It also gets everywhere.
                      Older blood or blood exposed to air for more than a few minutes will look dark anyway,and larger volumes will also look like a red jelly, (port or a good Merlot should give you the right colour).
                      For spatter trying dipping (someone elses) toothbrush or other stiff bristled brush in the colour and flicking it with a fingertip.
                      "Sanitatsjaeger" or "Sani" should bring a German medic running.
                      Peter
                      Peter
                      • stona
                        • Jul 2008
                        • 9889
                        I'll just add that your second effort has it for me. I thought you'd slipped with your scalpel!
                          Many thanks for the info and insight Peter,very much appreciated, and thanks for the info on sanitat jager, I never knew that, you learn something new everyday.
                          Thanks Steve, sometimes I think it would be easier to scalpel my finger.
                          Great info from everyone, thanks guys.
                            Steve i've just been assisting carrie with here GB dio and the best way we have found is TamiyaXf7 red paint and allow it to dry then add a few splashes of XF9 hull red to the middle of it, try it out and see what you think?
                            scott
                              Hey Ray
                              you don't happen to know the brand of Black oil you used?
