Hello Play mates.
After a bit of brain ache, way to many cigarettes and far to much coffee, I have made a section for the diorama builders here.
It was either that or split them off to the "most relevant section of the forum" With over 400 posts a frightening task for one man alone. So You have lucked out and gotten a forum.
HERE'S the catch. (Yes there is ALWAYS a catch).
To remain in the Dio section, the build must meet a few criteria:
The most simple way to put it is like this. A Tank on a base with a bit of mud and a bush is NOT a diorama. It is just a simple base to show it in its natural habitat. Take the same tank and put it on a base with other models, ie. an other tank, or other vehicles, some figures and the like it IS a diorama. This apparently the view of IPMS judges as well. So it seems like a good way to sort the issue.
So.. I will start moving posts soon to try and get all the DIORAMA builds in the correct box.
Subjects that do not meet the criteria will be moves to the section most relevant to the subject.
