Chip Board Bases
  • AlanG
    • 6296
    Chip Board Bases
    What is the best thing to seal chip board with for making diorama bases? Or is it a pointless task?
  • Alan 45
    • Nov 2012
    • 9833
    A good coat of primer will do the job an even coat of PVA or egg shell paint
      I'm a big fan of PVA in a fairly thick coat.
        • 18266
        I think also it will help a lot if you seal both sides. Chipboard can curl up if only treated on one side.
          Originally posted by \
          I think also it will help a lot if you seal both sides. Chipboard can curl up if only treated on one side.Ian M
          Good point, I always prepare mine in a frame so didnt think of that.
          • Alan 45
            • Nov 2012
            • 9833
            Yup both sides is best , even if you use ply board as well
            • Andy2035
              • Aug 2011
              • 730
              Tomato is ok but HP tastes tons nicer...o_O
              • AlanG
                • 6296
                Coat, door, slam!
                  TAXI FOR ANDY!
                  • Alan 45
                    • Nov 2012
                    • 9833
                    Andy you should be on stage !
                    Sweeping up
                    • Andy2035
                      • Aug 2011
                      • 730
                      So sorry all, I just couldn't help myself...
