The Road to Berlin,,
  • john i am
    • Apr 2012
    • 4019
    #31
    Looking great Monica will you be using hairspray for your winter camo effect
    • monica
      • Oct 2013
      • 15169
      #32
      so that you are all like it so far, Lee, Joe,Ken,
      yes John, thats the way in trying to do her, after the red/brown, 2 coats of hairspray, then the green, and another 2 coats of hairspray,
      then the final, 2 coats, one a russian/gray over a dirty white, so will let that set fr tonight,o_O
      and maybe get some time in the next 2 days or my sunday before i can get much more done, then do most of the chipping and put the bits and bobs on
      and for some reason the green is showing much more then in real life,
      never done this type of thing before so just trying away i was thinking off ? maybe it will work out ok ?
      hope you like her so far
      i do know that there is splatter, hear and there but will come out with the chipping,
      that AB and I just dont get along at times gggrrrrrrrrrrr ops:
      [ATTACH]85165.IPB[/ATTACH]
      [ATTACH]85166.IPB[/ATTACH]
      [ATTACH]85167.IPB[/ATTACH]
      • monica
        • Oct 2013
        • 15169
        #33
        well got a bit more of the old girl,done and she has seen better days, but for one of the
        last to roll off the line in late 43, and make it too 45, she has seen a lot off combat and
        without a good commander would not of made it,
        going for the look of just having winter camo splatted over the green, ? ops:
        so she is well over half done, hope you like her so far ?
        and started my 1st russian figure ever ,
        [ATTACH]85303.IPB[/ATTACH]
        [ATTACH]85304.IPB[/ATTACH]
        [ATTACH]85305.IPB[/ATTACH]
        [ATTACH]85306.IPB[/ATTACH]
        [ATTACH]85307.IPB[/ATTACH]
        [ATTACH]85308.IPB[/ATTACH]
        • monica
          • Oct 2013
          • 15169
          #34
          ok guys need a little help with the building if the scale looks ok, ?,
          there is a pic with the hight,of the 1st floor, or should i lower the floor by 10 or 15 mm, ops:
          because the figure is 55mm H,and i have 85mm to the top of the 1st floor, ?
          any help most welcome with this part as im just trying to wing it, ????
          [ATTACH]85311.IPB[/ATTACH]
          [ATTACH]85312.IPB[/ATTACH]
          [ATTACH]85313.IPB[/ATTACH]
          [ATTACH]85314.IPB[/ATTACH]
          • Lee W
            • Feb 2014
            • 4654
            • Lee
            • Sherborne
            #35
            Hi Moni, it's a deceiving angle, the level with the tank looks fine but then you put the figure there and it looks to high, if it was mine, I'd drop the first floor a couple of millimetres...see what everyone else comes up with?
            In the mean time keep up the good work but you still need to work on the scale of your cat, still slightly to big! :P
            Lee
              Hi moni I agree I think drop it a bit, but I think it depends a lot on how wide the floor on the outside of the building will be if you know what I mean.
              • monica
                • Oct 2013
                • 15169
                #37
                haha hi lee, yes see what a trouble maker he is eating my per-painted bits of rubble, he is just to big to put in a dio, lol,
                that is what i was thinking ,as well for the figure its far to high, but the tank should real be at about the top of the windows, which should make that about 70mm
                so to the 1st floor should only be about 75 to 80mm tops in a farm house, ?
                • monica
                  • Oct 2013
                  • 15169
                  #38
                  hi Ken, well what im trying to get is like the front part of the house is broken, with say about 1/2 to 3/4 lefted,
                  but I, think both you and Lee, has answered it by dropping it down by at lease 10 mm should like ok, ? i hope,
                  • monica
                    • Oct 2013
                    • 15169
                    #39
                    well lowered the floor but 10 mm,looks much better i thing so mite lower the top half but 10 to 15 mm as well,
                    as from what i can see most of the top floor is in the pitch of the roof ,not so much as a real floor so to say
                    [ATTACH]85334.IPB[/ATTACH]
                    [ATTACH]85335.IPB[/ATTACH]
                    [ATTACH]85336.IPB[/ATTACH]
                    [ATTACH]85337.IPB[/ATTACH]
                    [ATTACH]85339.IPB[/ATTACH]
                      Yes much better I think you're right about the top too.
                      • monica
                        • Oct 2013
                        • 15169
                        #41
                        ta Ken think lower that down till about only 20mm, and use the pitch in the roof ?
                        • monica
                          • Oct 2013
                          • 15169
                          #42
                          well i did lower the side wall down and thinks that dose not look to bad ?
                          like with the last pic you can see that the build do verairy alot in high,
                          [ATTACH]85390.IPB[/ATTACH]
                          [ATTACH]85391.IPB[/ATTACH]
                          [ATTACH]85392.IPB[/ATTACH]
                          • monica
                            • Oct 2013
                            • 15169
                            #43
                            well been a very long time since I ,have done any on this one,but got myshelf into gear and did a lot as you can see,
                            some may think over done with the weathering,in spots yes,but I do come back over and retouch were its a bit much,
                            as you can see from the pic,s the starting ones to the end were its been re whitened as this one dose have 4 or 5 crew at-rest,
                            so I have added some snow build up on spots,
                            well I do hope you like what i have done to this one,that's the great thing with Russian armor,i was in a very sad looking state,
                              more great work Moni,
                              • monica
                                • Oct 2013
                                • 15169
                                #45
                                ta Paul,glad your liking it,so far,
                                in away glad I,did leave it for a bit and ,got better skill,along the weathering line,
                                as I did wont to show the Russian green in spots as the winter camo was just painted on how ever they could,
