My first diorama. to go with my first model
  • eddiesolo
    • Jul 2013
    • 11193
    #31
    Just to add, I tend to use a strong superglue or contact adhesive for trees, rock etc, even silicone sealant has been use in the past. For grass I use PVA, brush it on and then springle or even dab on using tweezers especially around trees etc to show clumping.
    This picture of my Bate mansion in 1/72 shows trees etc I used the same techniques described.
    Si
    • Gern
      • 9212
      #32
      Looks excellent from where I'm sitting! Don't know what your 'rocks' are made from but this might help:
      http://www.bing.com/videos/search?q=model railway scenery&FORM=HDRSC3#view=detail&mid=9C3A43CE5F99D8 01968C9C3A43CE5F99D801968C
      Gern
        bit of plaster. and tried cork as well
        • eddiesolo
          • Jul 2013
          • 11193
          #34
          You shouldn't have had an issue using them, try some polystyrene chunks-just shape and then paint in acrylics. I use real stones and attach using sealant-they don't move then.
          Si
            For your first model and dio these is a sterling effort!!!! Don't be afraid to try the suggestions that have been posted.
            Most of all don't give up..
            Keep going!!!!!!!
              having a bit of a play at positioning things. painted some fuel drums and trying to make some tarp from tissue and camo netting from gauze.. thinking it looks too busy one side.. any tips?
              [ATTACH]89544.IPB[/ATTACH]
              [ATTACH]89547.IPB[/ATTACH]
              [ATTACH]89550.IPB[/ATTACH]
              • Gern
                • 9212
                #37
                I might suggest swapping the car and the gun/trailer. I think the extra details of the gun and trailer (compared to the smooth car) opposite the tree detail will balance it a little better - plus I don't believe they'd put an AA gun so close to a tree 'cos it cuts down the firing angles too much.
                Apart from that, which is only my opinion, this looks great so far!
                • Richi72
                  • Sep 2013
                  • 1100
                  #38
                  That looks nice.
                  For the Camo netting make a diluted wash of green or brown, then lay it over the place you want it to be, it looks very different then the white, and your tarp, put some plastic foil on the place where the tarp should go, and then put on the papertischu and after that gently wet the papertischu with diluted pva glue let it dry for 24 hours and then another layer of pva. After that is dry you can take it off and can take off the plastic foil and you will have a stable and stiff tarp.
                  Hope its a little clear what I said.
                  Cheers Richi
                    I think you're being ridiculously hard on yourself it looks great to me, ALL OF IT.
                    • monica
                      • Oct 2013
                      • 15169
                      #40
                      i do agree with Ken, you are being far to hard on your shelf the advice and info from Gern/Richi,, is what i would say as well,
                      looks great to me,
