Started work on one of the buildings, I have scratch built a dividing wall using balsa wood and coffee stirrers, I have also done a small bit of wood panelling, again using coffee stirrers.
As you can see this is going to be a slow process, but there will be wall paper in each of the rooms, along with furniture and lots and lots of debris
Another small update on the dio, I have started to do some more on the 1st building by adding the floor joists ready for the floor boards which will be added shortly
I love those diorama debris moulds. Mind you I haven't tried using them on the same scale as you. That groundwork looks first class. I'll be following this build closely.
