Looking great Terry , i thought the Hanomag looked more effective without the tracks on , a bit more derelict if you like , cheers tony
Restoration needed
I turn my back for 5 mins and suddenly there's a half-track and a barn! lol
Epic work man, superb so farComment
Thanks peeps. Tony I agree the track was only fitted to see what it would look like as are the front wheels. there is still a lot of work to do on the Hanomag before I will say it is done.Comment
After the last update I decided to do a bit more and here are the results. Once I dried the paint using the AB I used some spray mount and then added some sieved soil from the garden (that is after I had dried it out and then got SWMBO to do the sieving for me..). after this had been scattered over the required area and the excess removed I then repeated the spray mount step and then added some flock. This is another first for me using it and I have to say I don't think I did a flocking bad job.
[ATTACH]91259.IPB[/ATTACH]
[ATTACH]91260.IPB[/ATTACH]
[ATTACH]91261.IPB[/ATTACH]
[ATTACH]91262.IPB[/ATTACH]
[ATTACH]91263.IPB[/ATTACH]
[ATTACH]91264.IPB[/ATTACH]
[ATTACH]91265.IPB[/ATTACH]
[ATTACH]91266.IPB[/ATTACH]
[ATTACH]91267.IPB[/ATTACH]
I have done a bit more work on the Hanomag joining the top and bottom. Also added are the side pieces inside I have added some leaf debris to add to the abandoned look. There are a few other bits to add inside once I have finished them.[ATTACH]91450.IPB[/ATTACH]
[ATTACH]91451.IPB[/ATTACH]
[ATTACH]91452.IPB[/ATTACH]
[ATTACH]91453.IPB[/ATTACH]
[ATTACH]91454.IPB[/ATTACH]
[ATTACH]91455.IPB[/ATTACH]
[ATTACH]91456.IPB[/ATTACH]
[ATTACH]91457.IPB[/ATTACH]
[ATTACH]91458.IPB[/ATTACH]
[ATTACH]91459.IPB[/ATTACH]
[ATTACH]91460.IPB[/ATTACH]
[ATTACH]91461.IPB[/ATTACH]
