Rehashing Hurtgen forest diorama
  • rtfoe
    • 9065
    With little or no time for a new diorama, I have decided to rehash an old diorama which has never been entered in the Penang MALCOM competition. Some of you may have seen it before when I posted some finished dioramas in the past.
ID:	1240315 There's quite a lot to spruce up all-round including the figures and tanks. Ground work needs muddying a little or churned by the tracks. Decals are peeling and need to be redone.
    The other option is to continue with the Church archway Dio which also has quite a bit to do as well...
ID:	1240317 Click image for larger version
ID:	1240316 As for the Hurtgen forest I have started on preparing more trees and debarked some hedge stems from the garden...
ID:	1240318 I'm picking the straighter ones and probably adding three to four more trees.
    Wabble
  • scottie3158
    • 14189
    • Holbeach
    Wabble,
    I must admit I had forgotten all about the church scene. Really glad you have dug it out again.
      • 15604
      Like Scottie I don't remember the church archway Dio.
      • HAWKERHUNTER
        • Feb 2012
        • 1503
        • Steve
        • Halifax, West Yorks.
        The first picture of the finished diorama is brilliant. I am following with interest and from a modeller with limited skills I would be grateful for as much info, as you go along, on how you are building these scenes up please., Thanks.
        • rtfoe
          • 9065
          Wabble,
          Hi Scottie, I may have dug it out but it's just an option. I'm gonna go for the Hurtgen Dio except I was looking at the battle map and nowhere was Patton's 3rd Army in the Hurtgen. He was way to the south. Hodges 1st Army was involved with the Hurtgen campaign up North.
          I have changed everything to the Ardennes campaign which basically is where the battle of the bulge was fought. If everything starts to go pear shaped the I have the Church scene to fall back on.
          Wabble
          • rtfoe
            • 9065
            Seems like ages ago that I worked on the church scene way before my hall bladder operation halted it, Jim.
            Wabble
            • rtfoe
              • 9065
              Thanks Steve, I'll be doing the usual WIP as I go along so nothing much will be missed. Feel free to ask any questions on the process and hope my explanations can be of help.
              Wabble
              • rtfoe
                • 9065
                The sticks are still drying so I roumaged my spare parts box and found the old figures from a flood ruined diorama I did hundreds of years ago. One looks at them and you'll see why. Lots of puttying for scarfs, bandolias and leggings to beef them up to winter gear. I'll add wool caps and scarfs to cover their ears so I won't replace the heads. Repainting is going to be fun.
                Wabble
                  • 15604
                  Always good to see how you produce your stunning dios. Lots of useful tips to pick up along the way.
                    • 18871
                    Be good to see this come together. Always love the attention to detail you manage ?. Cat has to be a tabby, by the way….
                    • rtfoe
                      • 9065
                      Hi Jim, just hoping there won't be any major hiccups along the way. This is a pretty big Dio to fill.
                      Wabble
                      • rtfoe
                        • 9065
                        Hi Tim, that is if I were doing the church Dio but yes a tabby cat it will be.
                        Wabble
                        • rtfoe
                          • 9065
                          Hi, spent a few hours drilling attachment holes on the pine tree trunks, five around and spaced one cm per level. Six trunks altogether. I will be attaching the branches with CA.
ID:	1245181 Close up...the polystyrene block will hold the trees up when in WIP. Each level is drilled between the previous holes...don't know if the real tree branches grow this way as my artificial Christmas tree is set that way.
                          I've had enough of drilling for the day.
                          ​​​​​​Wabble
                            Jim R commented
                            Editing a comment
                            Interesting. Using an artificial Christmas tree as reference is a new one on me.
                          • rtfoe
                            rtfoe commented
                            Editing a comment
                            The one that the family had was so real looking when we put it up. Bought from NAAFI when my dad was still in the armed forces.
                        • scottie3158
                          • 14189
                          • Holbeach
                          Looks good mate.
                          • rtfoe
                            • 9065
                            Looks good mate.
                            Thanks Scottie, started putting up the branches. There's a patch in the middle that I haven't covered.
ID:	1245292Took me awhile to get into rhythm. Will have to remove the bottom set as they're facing the wrong direction.
                            Wabble
                            • minitnkr
                              minitnkr commented
                              Editing a comment
                              7th Armored was in Hurtgen towards the end.
