Rehashing Hurtgen forest diorama
  • scottie3158
    • 14196
    • Holbeach
    #16
    What are you using for the branches?
      • 15633
      I was going to ask the same question. Looking very good.
      • Steven000
        • Aug 2018
        • 2820
        • Steven
        • Belgium
        #18
        Much better result then my last batch of pine trees a few years ago ? well done, also curious about the branches, cheers
        • rtfoe
          • 9065
          #19
          Hi Scottie, Jim R and Steven, thanks.
          I use this dried plant from the florist. Don't know what it's called and is a far cry from pine needles which I need to coat with finely cut hemp rope to simulate that. What it does is give a believable structure of a pine branch to work with.
ID:	1245369 These are dried just before they open and bloom so there are two types the other has open petals.
          Check out your local florist or it could be growing in your woods...looks like some form of heather or lavender buds.
          Wabble
          • scottie3158
            • 14196
            • Holbeach
            #20
            Thanks mate. I have used dried asparagus ferns in the past. But they do look good.
            • rtfoe
              • 9065
              #21
              Hi Scottie, I have tried asparagus ferns in the past but find them too delicate and flat without enough body.
              Anyway assembling my trees need a set of instructions by the looks of it...
ID:	1245598 Each group has five branches and they have their aloted sizes for each tier. Not so fun part of making the Dio.
              Wabble
              • Richard48
                • 1883
                • Richard
                • Clacton on Sea
                #22
                Watching with interest Wabble Always amazed at your diorama skills.
                Seat pulled up.
                • rtfoe
                  • 9065
                  #23
                  Seat pulled up.
                  Thanks Richard, hope you got some warm pullovers as it's going to be quite chilly once I start adding snow.
                  Wabble
                  • rtfoe
                    • 9065
                    #24
                    Hi guys, second one near finish...the third in progress...
ID:	1245743 Click image for larger version
                    Tedious but needs to be done.
                    Wabble
                    • Steven000
                      • Aug 2018
                      • 2820
                      • Steven
                      • Belgium
                      #25
                      Great results Wabble, very nice work
                      • Airborne01
                        • Mar 2021
                        • 3934
                        • Steve
                        • Essex
                        #26
                        I'm learning as you go Richard, thanks!
                          • 15633
                          Those trees look very realistic. As you are very experienced in making monkeys I'm sure a squirrel or two would be well within your capabilities
                          • rtfoe
                            • 9065
                            #28
                            Thank you Steven.
                            Wabble
                            • rtfoe
                              • 9065
                              #29
                              You're welcome Steve, glad you're getting something out of it.
                              Wabble
                              • rtfoe
                                • 9065
                                #30
                                Jim, the monkeys were an experiment and lucky to have turned out respectable. After sculpting 16 of those I thought of giving animals a break or I'd go loony. Squirrels would be a good idea but wouldn't they be hibernating? Perhaps a ferret?
                                Wabble
