This idea for a diorama has been growing over the last few days.
Having already built a German Halftrack (1:35) and built up some generic German WW2 figures, it seemed an ideal opportunity to try a diorama using them both.
Not based on any particular event, just an idea that these troops have come upon the enemy and are staying out sight, hiding behind a small hill and old dilapidated building/wall, just trying to observe and carry out some reconnaissance.
Foam board base, not yet completed but some layers added.
I will be adding fine plaster/PVA mix to add texture to the base.
I have built up one corner to be a small hill/rise.
Once textured, I may also add some track marks, a lollipop stick (cut square at one end, seems the perfect tool to make the track lines), we'll see....
The idea for the final layout is not yet finalised, but will be something like this....
The wall is too "neat" at the moment, I have already drilled it so it looks like there are some bullet holes, but I think I will "distress" it a bit more, maybe chip some bit off, use a soldering iron to mimic a couple of shell holes, etc....
The final position of the oil drums, sandbags, etc is not set yet, juts put there for effect to see how they look, may add some other details too.
I like the fact that most of the figures are prone, or crouching or kneeling, so well suited to hiding and being discrete and recce'ing an area, etc.
I have a few more figures, so again, the final selection and position of figures is not yet set in stone.
Once the base is done, textured, etc I will also be adding natural features, eg: grass (via 2mm static grass, sprinkled) and some model making "foilage" and adding hard features, eg: some small rocks, cork, etc. I may even raid the wife's garden stock of fine grit, etc.
To be honest this is just a test/practice diorama for me, to see what it involves, how its done, whether I want to maybe do a few more, so it will be, as they say, a "learning experience".
