Originally posted by \
The hangar
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4. -
No hangar should be without drip trays for placing under those leaky aircraft. I made this one from an old tin foil takeaway carton flattened then formed into the shape of a drip tray. A coat of Matt varnish and some oils spots will finish it off.
Here's a closer look at some of the clutter, aircraft parts from the scrap box and plastic rod - avionics LRUs, work orders, red cantilever tool box, a newspaper and some aircraft parts. Paint tin for scale.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
I need some aircraft lifting jacks for the side of this hangar so out came the plastic rod and tube, this is as far as I have got tonight with just one main jack partially assembled using the Humbrol cutting mat to achieve the tripod alignment. A second will need to be built along with a nose jack which will be smaller of course and some trimming and finishing touches to all of them including bracing struts and pads.
Every hangar needs a set of gas bottles and this kit from Flightpath will look right at home in mine. The kit has options for a single cylinder trolley or as set of four with decals for both nitrogen and oxygen bottles.
Attached FilesOn the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
By happy coincidence the maintenance platform in the Airfix bomber resupply kit is near identical to the platform in the photo that has inspired this build.
[ATTACH]250777.IPB[/ATTACH]
[ATTACH]250778.IPB[/ATTACH]
[ATTACH]250779.IPB[/ATTACH]
[ATTACH]256897.IPB[/ATTACH]
[ATTACH]256899.IPB[/ATTACH]
