Tremendous work my friend! much too involved for an old hack such as I, can't wait to see it finished! .......Jim
Castle gate entrance
Originally posted by \I've seen some lovely work on here, but this has to be one of the best, excellent scratch building at it's best, there is so much to look at and take in, really looking forward to the next update Richi
just superb,
would lov to know how you made all the hinges for doors and gates,
loving this one,Comment
I wanted to write something, but all I can do is place this:
[ATTACH]110606.IPB[/ATTACH]
Wow thanks alot for these great compliments.
Originally posted by \C'mon Richi, don't keep us all in suspenders! How did you fill in between your stones and get such a fabulous result on the colours?
I made a test piece and tried different stuff but here is what worked the best for me,
as a filler i used light spackle normally used with rc planes, i coated the bricks with a thin layer and waited about 10 minutes, then i took a thin sponge (1 cm) that was glued to a piece of wood to keep it as flat as possible, sprayed some water on it and started to wipe the cork stones clean.
After each 2 or 3 wipes i cleaned the sponge and repeated this until i was satisfied. After about 2 hours i went over the cork stones with a small flexible steel brush to get covered up details by the spackle back and let it dry for 2 days.
By cleaning the cork stones with the steel brush i got an irregular color of the stones with shades of brown and white which was perfect to get a base grey tone that vary in color (like a pre shading)
For the paint, I used a dark grey base tone mixed from white and black from reeve's acrylics and sprayed it with the AB, after that was dry i used a lighter mix to gave the stones the first grey tone, at the moment its a medium blue grey, but that will change if i build up the different grey tones to create depth.
Cheers RichiComment
Originally posted by \would lov to know how you made all the hinges for doors and gates,
I used my computer to draw the hings and then i let the machine cut them , after that i drilled the 0,5mm holes.
Glued them in place and put a piece of sprue in the drilled holes.
After that i cut of the sprues and heated up the ends to get a bold end.
Cheers RichiComment
I'm proper impressed with this Richard. Brilliant work........ Not a lot else to say that hasn't already been said.Comment
Hi all,
so here's a small update on the Castle build. I did some work on the moat at least the bottom of it.
I made a transparent box of vivak material 0,75mm as a base too put some scale water on, so i didn't need too put a 2cm layer of resin in.
[ATTACH]112358.IPB[/ATTACH]
[ATTACH]112359.IPB[/ATTACH]
[ATTACH]112360.IPB[/ATTACH]
[ATTACH]112361.IPB[/ATTACH]
[ATTACH]112362.IPB[/ATTACH]
[ATTACH]112363.IPB[/ATTACH]
[ATTACH]112364.IPB[/ATTACH]
[ATTACH]112365.IPB[/ATTACH]
[ATTACH]112366.IPB[/ATTACH]
[ATTACH]112367.IPB[/ATTACH]
But i didn't like it that much so i cut it out and glued in a new bottom that is a little higher.
[ATTACH]112368.IPB[/ATTACH]
[ATTACH]112369.IPB[/ATTACH]
[ATTACH]112370.IPB[/ATTACH]
[ATTACH]112371.IPB[/ATTACH]
[ATTACH]112372.IPB[/ATTACH]
Started to work on a figurine.
[ATTACH]112373.IPB[/ATTACH]
[ATTACH]112374.IPB[/ATTACH]
And painted the bottom of the new moat.
[ATTACH]112375.IPB[/ATTACH]
[ATTACH]112376.IPB[/ATTACH]
[ATTACH]112377.IPB[/ATTACH]
Next up was making a plate of resin about 4 mm thick.
[ATTACH]112382.IPB[/ATTACH]
[ATTACH]112383.IPB[/ATTACH]
[ATTACH]112384.IPB[/ATTACH]
[ATTACH]112385.IPB[/ATTACH]
Cut it to fit the moat
[ATTACH]112386.IPB[/ATTACH]
[ATTACH]112387.IPB[/ATTACH]
[ATTACH]112388.IPB[/ATTACH]
[ATTACH]112389.IPB[/ATTACH]
[ATTACH]112390.IPB[/ATTACH]
[ATTACH]112391.IPB[/ATTACH]
[ATTACH]112392.IPB[/ATTACH]
So i think it looks a little like frozen water, now for some details under the water, i used some candle wax melted on the bottom side of the resin to recreate some air pockets under the ice. After the wax was on I used an flat iron and some wax paper too get rid of the drops so it would look like a large splash. then i turned the plat and, (got this from a book)
[ATTACH]112393.IPB[/ATTACH]
[ATTACH]112394.IPB[/ATTACH]
[ATTACH]112395.IPB[/ATTACH]
[ATTACH]112396.IPB[/ATTACH]
[ATTACH]112397.IPB[/ATTACH]
[ATTACH]112398.IPB[/ATTACH]
[ATTACH]112399.IPB[/ATTACH]
[ATTACH]112400.IPB[/ATTACH]
[ATTACH]112401.IPB[/ATTACH]
glued the plate in place with modge pod,
So thats all for the moment.
Thanks or watching.
Cheers Richi
