Eye Deep In Hell
  • monica
    • Oct 2013
    • 15169
    #46
    looks great Jim,I think your nailed this part of it,
    real do like the layout
    • grumpa
      • Jan 2015
      • 6142
      #47
      Thanks Monica, lots more to go, got to start making sandbags, couple hundred the way I see itops: I don't want to cut any corners detail wise
      • monica
        • Oct 2013
        • 15169
        #48
        which way do you do your ones ?
        i use clay and just roll it out to about 10mm,then cut them about 15mm long
        flatten them down,and just with a cocktail stick draw aline around them,
        and nip in the ends
        • grumpa
          • Jan 2015
          • 6142
          #49
          and nip in the ends
          That's almost exactly how I make mine only with "Playdough" made for kids, non toxic, potato and fiber based so they dry out and harden nicely after a while.
          • monica
            • Oct 2013
            • 15169
            #50
            yes i use that as well get 5 different colored tubs for $2.oo much cheaper than clay,
            set in about 2 or 4 days rock hard,
            • grumpa
              • Jan 2015
              • 6142
              #51
              Just got figures in mail, nice detail but some flash and seams but I'll clean them up, a bit of a delay in progress as other things pop up but want to keep a steady pace, more pics coming soon
              • monica
                • Oct 2013
                • 15169
                #52
                will look forward to seeing the next progress pic,s
                • grumpa
                  • Jan 2015
                  • 6142
                  #53
                  Bit more done, loooong way to go.....[ATTACH]113393.IPB[/ATTACH]
                  [ATTACH]113394.IPB[/ATTACH]
                  [ATTACH]113395.IPB[/ATTACH]
                  [ATTACH]113396.IPB[/ATTACH]
                  [ATTACH]113397.IPB[/ATTACH]
                  [ATTACH]113398.IPB[/ATTACH]
                  [ATTACH]113399.IPB[/ATTACH]
                  [ATTACH]113400.IPB[/ATTACH]
                  • Richi72
                    • Sep 2013
                    • 1100
                    #54
                    This is taking shape Jim. Looks great the trench the walls, sandbags. awesome, great job so far.
                    Cheers Richi
                    • bazers
                      • Oct 2013
                      • 2611
                      #55
                      Coming along Jim ,sandbags a bit bright aint they!!!.
                      • grumpa
                        • Jan 2015
                        • 6142
                        #56
                        Now, now Barry, you know they will be painted as close as possible to the real thing. not even near applying any color yet, a few more structural things to go . Then working the "ground" with miniaturized debris of war etc... then all gets a brownish black wash, then dry brush colors in, gives depth and color, definitely not something to rush. Barbed wire and figures go in last.....Jim
                        • spanner570
                          • 15420
                          #57
                          Some great scratch work going on Jim. Excellent stuff......
                          I know there's plenty still to do and it's early days, but keep in mind (Which I'm sure you are) after a preliminary allied artillery bombardment, tank fire and the odd grenade or two, there wouldn't be much left of the trench and a large amount of the sandbags would be burst and scattered to hell and all....along with the wire, timber and mud.
                          Looking good.
                          Ron
                          • grumpa
                            • Jan 2015
                            • 6142
                            #58
                            Looking good.
                            Ron
                            Thanks Ron like you say "early days" much still to do. Debris will be wide spread but keep in mind once tanks started to be used with some regularity, they found that "over shelling" an area only made it much harder for the tanks to traverse severely broken ground with most ending up bogged in shell holes etc... Plus the element of surprise was lost with big bombardments, hence many trenches were taken virtually intact with much stores and weapons captured after panicking Germans fled for the most part............Jim
                            • monica
                              • Oct 2013
                              • 15169
                              #59
                              looking good Jim,I,m liking this one alot,
                              real like the work with the trench,with the added platform run in it,
                              the sand bags look good as well,enjoying this whole build,
                              keep up the good work,
                              • grumpa
                                • Jan 2015
                                • 6142
                                #60
                                Thanks Monica, but don't worry I'll rough things up a bit before all is said and done. Still in very early stages, maybe I'll do some grenade damage to the trench here or there, some busted sand bags and timber damage, also will try to scratch up some ammo boxes, tools, tarps and the like. In no rush, just taking my time about it. Will search the scrap boxes and put together a few "unfortunate ones" you know me, some just don't get out alive...........Jim
