part two blown bridge
  • bazers
    • Oct 2013
    • 2611
    Have built bridge and destroyed it i think there is to many timbers on ground (and i did not use all of them) have split lower centre timber since taking photo.
    what do you guys think.[ATTACH]115098.IPB[/ATTACH]
    [ATTACH]115099.IPB[/ATTACH]
    [ATTACH]115100.IPB[/ATTACH]
    [ATTACH]115101.IPB[/ATTACH]
    [ATTACH]115102.IPB[/ATTACH]
    Outstanding, this will I know be amazing.
    • monica
      • Oct 2013
      • 15169
      that's right on the money ,Barry I do real like the look off it,
      what did you mold the cliffs from,as there so good,
      • Gern
        • 9218
        Some of the timbers would have been thrown clear in the explosion so leaving out a few is fine. I think you've nailed it!
        • bazers
          • Oct 2013
          • 2611
          Thanks guys,
          Got idea from u tube Mon its so easy ,just make whatever shape you want i used foam pices glued to gether ,mix up plaster of paris or wall filler make shure its white for painting Add water so its guite thick but still runny get a piece of tinfoil used for cooking and scrunch it up untill you can see rock shapes not to much or the rocks will be tiny , add plaster over the foam hill or whatever you are building and place foil over plaster with light presure press onto plaster and follow shape of rocks with your finger nail making shure there is plaster under foil ,leave to dry and remove foil
          and there it is it sounds a long process but its realy easy .
          • Snowman
            • Oct 2014
            • 2098
            I totally agree, as well as some of the timber been vaporised or reduced to kindling by the blast.
            Did anyone see "Mythbusters" on the telly, instead of just blowing up the boat, they literally vaporised it with a submerged charge!!
            • bazers
              • Oct 2013
              • 2611
              Great idea of yours Dave thanks.
              • eddiesolo
                • Jul 2013
                • 11193
                Think it is spot on Barry, looks realistic and what would have happened. Nice work mate.
                  nice work I'll be watching with interest regards cry .
                    Don't be put off, if they are the timbers required for the tower then it makes sense that they are the timbers you would see in the bottom of the valley. Don't worry if it looks too much, you have gone through the perfect process to prove you are right. I wouldn't worry and leave it exactly as it is.
                    • grumpa
                      • Jan 2015
                      • 6142
                      While not a tressle expert I would expect there would also be some smaller timbers involved for extra bracing etc.. I do agree that a lot of the timbers would have been scattered to the heavens. Also a lot of splintering would be apparent, seems more like a collapse than an explosion. I usually don't offer advise or opinion because it's usually not well received but I do believe you are open minded enough to receive it in good humor....................Jim
                      • monica
                        • Oct 2013
                        • 15169
                        ta Barry i must try that out one day,
                        • bazers
                          • Oct 2013
                          • 2611
                          Yes you right about the splintering Jim thats the next job removing pieces, splintering ends painting and fixing back in same place !
                          Always welcom good advise.
                          • spanner570
                            • 15402
                            This is taking shape nicely Barry.....There's just one thing bugging me and I realise we all have our own interpretations when constructing dios., particularly the effects of explosions, but the rails don't look quite right to me.
                            I would suggest that to destroy and bend the rails as you have them would taken a colossal explosion, leaving nothing left of the bridge, scattering the structure far and wide, leaving only small shards of timber and rubble. Destroyed wooden rail bridges usually have at least the rails intact hanging in mid air, sometimes with some sleepers still attached....Just my own thoughts.
                            I daresay eyebrows will be raised by my suggestion, but that is all it is, and I agree with Jim that you are open minded to receive, as I see it, my well meant observation.
                            The initial wrecking of the bridge is first class. It does take a bit of steeling yourself to deliberately destroy work that has been stuck together, but it's the only way to achieve any sort of realism.
                            Excellent work thus far......
                            Ron
