Winter patrol
    Originally posted by \
    Hey Polux great job!is the guy riding the panzer a war amputee? hes missing a hand :haha:
    The pics look good and the snow looks fantastic and cold.
    Hi Aaron!
    No,no... It's not a war amputee!! He's not finished yet!!
    Thanks for your comments mates!
    Regards
    Polux
      Hi again....Here you have the color photos!
      When I finishes it, I don't know that photos to put....hotographer:
      Thanks for looking
      Regards
      Polux
      Ps: Thanks Ian, I will do!!
      [ATTACH=CONFIG]45342[/ATTACH][ATTACH=CONFIG]45343[/ATTACH][ATTACH=CONFIG]45344[/ATTACH][ATTACH=CONFIG]45345[/ATTACH][ATTACH=CONFIG]45346[/ATTACH][ATTACH=CONFIG]45347[/ATTACH][ATTACH=CONFIG]45348[/ATTACH][ATTACH=CONFIG]45349[/ATTACH][ATTACH=CONFIG]45350[/ATTACH][ATTACH=CONFIG]45351[/ATTACH][ATTACH=CONFIG]45352[/ATTACH][ATTACH=CONFIG]45353[/ATTACH][ATTACH=CONFIG]45354[/ATTACH][ATTACH=CONFIG]45355[/ATTACH][ATTACH=CONFIG]45356[/ATTACH][ATTACH=CONFIG]45357[/ATTACH][ATTACH=CONFIG]45358[/ATTACH]
      What an excelent piece of work, nice story line your figures are great and i really like the panzerIV well done.
      scott
        Thats great work Polux.
        Theres a nice balance of everything in the dio, lots to look at but isn't cluttered.
          Hi Mates!!
          Finally I can say the "Winter Patrol" is Finished!!! Oh my God!!! :thumbsup:
          But... I have a bad news... With my nerves and a simple wrong moviment, while I was preparing everything, I have broken accidentally the electrical cables of the lampposts!! I cannot believe it!!! Now there is impossible to weld again, without destroying the whole soil, thing that I will not do!!
          I will miss these small lights!! That nice one saw in the darkness ... that is bad luck!!
          :smile3:
          Only a light works, that of the house!! :emo2:
          Tomorrow I will do a few good photos (will try) and on Tuesday I will publish them. I would like to publish here, but do not if is it correct, probably to open a new thread in dioramas?? (moderator advice)
          I am very satisfied with the final result and especially with the snow and the ice! I have learned very much and have amused myself a "heap"!! I have to return do other one!!!
          Thanks for looking friends!!
          Best regards
          Polux
            • 18272
            Shame about the light!
            You can post the pictures in the diorama section. Just make sure thre are lots of them!!!
              • 22788
              #96
              Yes sorry to hear about the lights, but still a stunning diorama Polux. I'm looking forward to the final photos
                You say the cables are broken/snapped?
                There's a little trick i've used that may work if you can still get to the cables. ... basically if you can still see the cable/wire you can normally fix it with this method.
                If you attach a dress makers pin to each end of some thin electric wire you can use the pins and stick them into the existing cable (through the plastic insulation/covering or into the ends of the cable) and rejoin the broken circuit.
                This can be a permenant fix if you can hide the new wire from view.
                  You say the cables are broken/snapped?There's a little trick i've used that may work if you can still get to the cables. ... basically if you can still see the cable/wire you can normally fix it with this method.
                  Thanks friends!!
                  And thanks Colin for this great advice.
                  But it is impossible to weld without raising the soil. The lampposts are in front of the diorama, and they cross the whole set up to behind the houses. In the average point (if I do not remember badly) the weld was there. The cables were in a few small channels, if I do not break the soil it is impossible to come them!
                  I am very obstinate, in my next diorama I will return to put light, and with better luck!!
                  Hi Ian, I will publish 26 photos!! Hope it's Ok!!
                  Thanks for looking
                  Best regards
                  Polux
                    • 18272
                    Hi Polux 26 photos! No Problem! It is such a great diorama I will enjoy each and every one of them.
